Forum Index : Microcontroller and PC projects : SP0-512 Text to Speech IC
| Zonker Guru Joined: 18/08/2012 Location: United StatesPosts: 772 |
Hey Lou..!! Had the fishin pole in the water and look what I caught... Just the thing we are looking to find for the ham repeater project Here is the Website Check it out man... Looks like a winner..! 2014-09-11_022516_Text_to_Speech_IC_SP0-512-Datasheet.pdf And Guess what... It's PIC C code... They will let you get it... Awesome...! |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1782 |
Hi, Seems to be a mail contact?
regards Michael |
http://www.speechchips.com Microblocks. Build with logic. |
| micronut Newbie Joined: 03/09/2014 Location: United StatesPosts: 37 |
The page says "Source code license available". That to me implies that there is a cost in getting the source code. I wonder how much? I'll stick with my SP0-256 I got a long time ago at Radio Shack. ![]() |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1160 |
Hi, did anybody remember S.A.M. (Software Automatic Mouth) on C64? I found two very interesting links on Letsmakerobots: - S.A.M. C-Code - Cantarino (Sketch for Arduino) It looks very interesting to make your own speech-chip with this... Frank |
| halldave Senior Member Joined: 04/05/2014 Location: AustraliaPosts: 121 |
I checked out http://www.speechchips.com a while ago... everything was on backorder then and I see still is..... sort of looked promising but i think the site / idea is not being updated or developed anymore |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
You could also try "Talkie" for the Auduino. Dave. |
Bummer... I thought I was on to something... next... |
@ cosmic frog Thanks for your hint - the speech quality is very impressive! Unlikely is there no text to phonetics converter implemented - it looks very difficult to let Talkie say any "normal" text... Frank |
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
hello Zonker, I am also a hamradio, F1FCO, and I build some ham repeaters (phone and ATV...) speech syntheziser have phonemes in english... bad for me in france I use Sound Modules like this : http://www.4dsystems.com.au/product/SOMO_14D or WTV020-SD-16P http://www.icstation.com/product_info.php?products_id=1678#. VBaIBxaBZFc you can find it on ebay at low cost you can adress 512 files with your owns messages Pierre 73s de F1FCO |
Thanks Pierre I had talked to Lou about the SOMO II module before... If we can't find a good easy to use talking chipset, then this might be a good way to go... To bad you can't store "play lists" or groups of word or phrase files... The MM will have to do that I think... I have also did a little play time with some of 4-D's Display modules... |
