Local Time 12:29 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using a MAX6675 SPI Thermocouple amp...
Posted: 02:59pm 10 Sep 2014
Hi all.
I am looking at these on eBay.
Output from the 6675 chip is SPI interface, and as I have never used this before, do any of you here see any issues connecting this thing to a MicroMite chip?
Can't upload the PDF, as it is bigger then the upload size limit, but HERE is a link to the page and download for the PDF.
Zonker
Posted: 04:16pm 10 Sep 2014
Hey Grogs..
I have used the MAX31855 part for the EIS system and it seems to work well.. I spun up a chunk of spaghetti code for the color MM that displayed bar graphs and such... I want to get back on it when things settle down a bit... (right) Anyway, Maxim also makes a ready to go module that offers a way better frontend that has protection and proper termination caps, ect.. I didn't see any such things on the Ebay module... I first got a couple of the chips, and played around, they worked ok.. But, after getting the modules, I noticed way better readings, and after getting the PDF's on it, I saw the proper "front end" circuitry.. I can dig it up if you want...
jman
Posted: 06:55pm 12 Sep 2014
Hi
I have used the Max31855 Max31855 Datasheet
They look real similar
Here is my code for the MAX31855 not very tidy but it works
Dim byte(4)
SetPin 6, 2 'set rx pin As a digital input
SetPin 7, 8 'set tx pin As an output
Pin(4) = 1 : SetPin 4, 8 'set clk pin high Then set it As an output
Pin(5) = 1 : SetPin 5, 8 'pin 11 will be used As the enable signal
start:
Pin(5) = 0 'assert the enable line (active low)
For I = 0 To 3
byte(I) = SPI(6, 7, 4) 'get the first byte from the slave
Next i
Pin(5) = 1
tmp = (byte(0) * 16) + (byte(1) \ 16)
tmpdec = byte(1) \ 4 And &B00000011
tmpdec = tmpdec * .25
tmp = tmp + tmpdec
tmp1 = tmp + Tmp1
Pause 100
sc = sc + 1
If sc < 10 Then
GoTo start
Printme:
tmp = tmp1 / 10
tmp$ = Format$(tmp,"%6.1f")
? tmp$
sc = 0
tmp1 = 0
GoTo start
Jmam
Posted: 07:12pm 12 Sep 2014
Thank you - I will study your code.
I am also looking at the AD595 chip, as it outputs a voltage - 10mV/'C
The 595 can be had on eBay for about $12, but is VERY simple to get up and running, so should be as simple as reading the pin set as analog in - T=PIN(10) kind of thing.Edited by Grogster 2014-09-14
