Local Time 12:29 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : E-test - what actually is it?
Posted: 11:13am 09 Sep 2014
I've wondered about this when I order from Itead Studio.
One of the options is E-test, and you can have None, 50% or 100%.
Selecting this does not seem to alter the final price one iota, so I always select 100%.
I am ASSUMING that this is an electronic continuity test of all the etched tracks once the board is finished - would that be correct, or does it actually mean something else?
palcal
Posted: 11:21am 09 Sep 2014
I assumed the same as you did. Maybe 50% is only checking one side, but why on earth would anyone only want to check 50% when it doesn't seem to cost anything.
Maybe send them an email, they seem to be an obliging lot from my dealings with them.
Paul
Posted: 11:50am 09 Sep 2014
Yes, good advise, Paul - I might just do that.
Posted: 04:07pm 09 Sep 2014
Grogs,
Its not worth a bag of Politician's promises (certainly Chinese Fabs).
I remember reading somewhere about e-Test and its explanation and it doesn't mean what we would think and it has different meanings from Company to Company.
For example it `may' test that plated holes are fully plated, it `may' test track connectivity, it `may' test track isolation from other tracks, it `may' check everything, it `may' check nothing.
I would have thought that it meant full test of tracks going to where they should + tracks not shorted to others + plated holes fully plated.. but the article I read stated basically what I mentioned above.. I was a bit surprised as it makes a mockery out of the term e-test.
I will try to find that article.
