Forum Index : Microcontroller and PC projects : It the f * * * ing keyboard !!!!!!!
| hitsware Guru Joined: 23/11/2012 Location: United StatesPosts: 535 |
Unbelievable ! ( even though someone mentioned a similar experience )
A prophylatic for Gizmo ColorMaxiMite SD drive |
Interesting. Old PS/2 keyboards for computers - you just about can't give them away - there are thousands of 2nd hand ones all over the place. Twenty bucks seems a little rich for something that most people can get for nothing by asking the right person. Smoke makes things work. When the smoke gets out, it stops! |
I wanted (and still do) the 89 key type. Way more ergonomic
Not that many of those around . Got this one now .... Seems to work OK (USB and all).......... |
| cosmic frog Guru Joined: 09/02/2012 Location: United KingdomPosts: 311 |
Well at least it didn't take you nearly two years to work it out like it did me. After changing the memory card then the card slot, changing the ubw32,reflowing all the solder points on the usb32, trying different power supplies the only thing it could be was the keyboard, and it was! It's now very stable and works great! Dave. |
If I hadn't remembered your recent post on the subject I might still be struggling with it ..... Thank You |
