Local Time 11:20 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : QUESTION TO PORT COMMAND
rentner111
Posted: 09:23pm 25 Aug 2014
I have found when working with the PORT command, that the order of the port pins when reading and writing is different. Why is that?
example: PIN1=D0 PIN2=D1 PIN3=D2 PIN4=D3
When reading:
Levels at the PINs: 1-0-0-0
a = PORT(1.4)
print a = 1
In writing:
a = 1
PORT (1,4) = a
Levels at the PINs: 0-0-0-1
With thanks for an answer
Posted: 09:49pm 25 Aug 2014
Your input uses 1.4 -- is that right? A single floating point number?
JohnEdited by JohnS 2014-08-27
Posted: 10:52pm 25 Aug 2014
Erwin, you seem to have found a glaring bug
It is so obvious that I am amazed that I never spotted it in testing, even more amazing is that no one else has spotted it since the PORT() function was introduced in V4.1 over two years ago.
What is going on here? Are you the first to have used the PORT() function?
I am sure that you are right but I am going off to test it - a fix will be in the next version.
P.S. The bug is in the PORT() function, the bits returned are in reverse order. The port command is OK (but separately there is also a bug in the Maximite 4.5 version to be fixed).
hitsware
Posted: 03:33am 26 Aug 2014
Not for lack of trying I tried with 4.5. No go. Asked here and was refered to a previous post where the problem was declared a bug. That person had reloaded 4.4 and it worked. I tried 4.4A (perhaps the 'A' was the problem) and a different problem. When I tried to use PORT I'd get (IIRC) a 'pins not declared outputs' even though I had....
edit: oops ... function rather than commandEdited by hitsware 2014-08-27
Posted: 04:17am 26 Aug 2014
Yes, as I said, there is a known bug in the Maximite version of the PORT command.
For a simple command/function it has a lot of issues
Posted: 02:30pm 26 Aug 2014
I used the PORT command in the PRINTER sub that was developed here a while back with lots of input from others, and I never had a single issue with the command itself, if that is of any help. However, I was writing to the port using OC outputs. As I was never reading the port, this may have been why I never had any issues....
Posted: 04:44pm 26 Aug 2014
The only time I have used the PORT function is for the Coffee machine.
I do remember thinking at the time that the bit order was different to what I expected but didn't go back and investigate any further - the coffee machine does turn on.
It would only be if you are using the PORT command and function that the difference would be obvious.
