Local Time 10:19 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Quick DS18B20 question....
Posted: 04:36pm 21 Aug 2014
As the Micromite manual states on page 17, these temp sensors are available cheaply on eBay, and I have found some nice encapsulated ones here.
The manual states that the sensor can work on parasitic power from the I/O pin, but I also assume I can run the sensor in the "Normal" way, with just the data line coming back to the I/O pin.
QUESTION: Do you still need the 4k7 pull-up resistor if you are using the more standard(non-parasitic) power?
EDIT: Manual says:
The DS18B20 can be powered separately by a 3V to 5V supply or it can operate on parasitic power from the Micromite as shown on the right. Multiple sensors can be used but a separate I/O pin and pullup resistor is required is required for each one.
That's fine, but does that mean you have to use separate pull-ups for each sensor only when used with parasitic power, or separate pull-ups no matter what?Edited by Grogster 2014-08-23
Posted: 10:23pm 21 Aug 2014
For each I/O pin used with a single DS18B20, you need a single pull-up on the I/O pin.
I would advise against using the one-wire search function to address multiple one-wire devices on a single I/O (via bit-banging). The OWSEARCH was dropped (and for good reason IMHO).
As the manual suggests, for multiple sensors, use a single sensor on it's own I/O pin and include one pull-up on that I/O.
If you need a large number of sensors then I would use a dedicated MM and then I2C the data to the main MM (I2C example given in manual App B). This way you could have upto 31 sensors on a 44-pinner and talk to a Master MicroMite with all the necessary data.
For sensors spaced further apart I would recommend a wireless link - currently working on a lower power version of that (but having a few 'teething' issues.
EDIT: And yes, you do need the resistor whether you are using parasitic power or normal power to the sensor.
WW
Edited by WhiteWizzard 2014-08-23
Posted: 10:47pm 21 Aug 2014
Understood - thanks.
