Local Time 10:18 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DS18B20 2 or 3 wire?
Posted: 12:08pm 10 Aug 2014
Hiya
Building a solar hot water controller based on the uMite, and will be using a few DS-18B20 senders. Geoffs SC articles show how the sender can be used in either 3 wire or 2 wire with parasitic power configurations.
Just wondering, if there was any pro/cons for either?
atmega8
Posted: 12:17pm 10 Aug 2014
The datasheet will give you the Answers.
nrtfm
For short distance and one device parasitic power IS ok.
Posted: 01:09pm 10 Aug 2014
Yeah that was what I thought. My runs will be up to 3 meters, and there could be a bit of electrical noise on the supply, so I'll use 3 wire.
vasi
Posted: 03:38pm 13 Aug 2014
Hi Glenn,
Always a 3 wire cable and a good library, capable of detecting any error on the bus. The only capable one (detecting bus short circuit, sensor absence, bus error - all very important in critical applications like egg incubators) I saw, was written for AVR microcontrollers. I will try to replicate it for PICs when time will permit. Sometime, a very noisy environment will make the temp. readings impossible so you need to take care when routing the bus.
Elvish name: Mablung Miriel
Beyound Arduino Lang
Zonker
Posted: 03:48pm 13 Aug 2014
Maybe make the run in a fully shielded type cable would help... Also, maybe going to the 5v part might get more distance... I think there might be a repeater IC also... Edited by Zonker 2014-08-15
