Local Time 09:11 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : uM Recursive control
hwholmes
Posted: 08:51am 04 Aug 2014
New to the forum but hardly to life, retired 7 years from teaching distributed control systems configuration, programming, and graphics.
Now having fun with microcontrollers with my model railroad.
Happened upon a comment on the PicAxe forum about the uM and picked up a couple of preprogrammed chips. WOW! If the speed holds up this should be just what I have been looking for.
Anyway, to get on topic I have only been playing around learning the language for a few days but I have already written a recursive program to solve the clasic puzzel, TOWERS of HANOI. It is just in text format since it is run through the VT100 interface (I used teraterm - I'm not sure if it is the screen size I switched too, but it doesn't run on my MMEdit VT100 chat screen.)
Here it is, if anyone is interested.
Comments welcome.
Bert
'''''''''''TOWERS of HANOI''''''''''''
''''''''''''By H W Holmes'''''''''''''
''''''''''''July 31, 2014'''''''''''''
'This program plays the game of Towers of Hanoi for you.
'It is a programing exercise in recursion, that is,
'where a subroutine, in this case "TOWER", calls itself.
'It plays on a MicroMite using a VT100 terminal .eg Tera Term.
'It does NOT play in my chat window of MMEdit.
INFO:
'''Display Constants'''
Delay = 500 ' Change for speed of play
TopRow = 8 ' CHANGE THIS TO MOVE Game UP OR DOWN THE SCREEN!
''Tower Pieces''
Dim TP$(9)
TP$(0) = " M " ' Empty Peg
TP$(1) = " 1M1 " ' Level 1
TP$(2) = " 22M22 "
TP$(3) = " 333M333 "
TP$(4) = " 4444M4444 "
TP$(5) = " 55555M55555 "
TP$(6) = " 666666M666666 "
TP$(7) = "7777777M7777777" ' level 7
TP$(8) = "TTTTTTTTTTTTTTT" ' Base
TP$(9) = " " ' ERASE disk
Dim PL(3) 'Pin Level
HMD: 'How many disks?
ClearScreen
HOME
' c 1.1
Print "This program plays the game of Towers of Hanoi for you."
Print "Object: To Move Disks from 1 Pin To Another, 1 pin at a time,"
Print " never puting a larger Disk on a smaller one."
''''Display''''
D=0:S=0:E=0
ScreenBuild
Print
DK:
Print "How many Disks (1-7) " ; : GetDig D : Print D
If D<1 Or D>7 Then Print "Disk Count Out of Range! -> "; : GoTo DK
SP:
Print "Starting on Pin (1-3)"; : GetDig S : Print S
If S<1 Or S>3 Then Print "Pin # Out of Range! -> "; : GoTo SP
EP:
cnt = 0
Print "Move to Pin (";
If S<>1 Then Print "1";: cnt = 1: Print" OR "; ' 1 was not chosen to start
If S<>2 Then ' 2 was not chosen to start
Print "2"; : cnt = cnt + 1
If cnt = 1 Then Print " OR ";: Print "3"; 'must be the other not chosen
Else
Print ") "; : GetDig E : Print E' get end destination pin
If E<1 Or E>3 Then Print "Pin # Out of Range! -> "; : GoTo EP
If E=S Then Print "Pin # Same as Start Pin! -> "; : GoTo EP
Print
SUMARY:
Print "Move" D " Disks From Pin" S " TO Pin" E " " ;
Print "Correct? (Y,N) ";: GetKey A$ ' Did you type your choices correctly?
Print A$; : If (A$ = "N") Or (A$ = "n") Then GoTo HMD
If (A$ <> "Y") And (A$ <> "y") Then
Print : Print "Press Y or N - "; : GoTo Sumary : EndIf
SETUP: 'c y,x notes below indicate cursor position for calulating page layout
ClearScreen
HOME
Print " T O W E R S O F H A N O I"
' c 2.1
Print "Object: To Move" D " Disks from Pin" S " To Pin" E
' c 3,1
Print "1 pin at a time, never puting a larger Disk on "
Print "a smaller one."
Print
' c 6,1 1 2 3
' 123456789012345678901234567890123
Print "Moving Disk _ From Pin _ To Pin _."
' c 6,1
SHOW_MOVE
Sub SHOW_MOVE d,s,e 'fills in the above blanks for disk and pins
yx 6,13: dS d: cr 10: dS s: cr 8: dS e
Pause Delay
' c 5,33
PLAY:
ScreenBuild
Sub ScreenBuild
yx (toprow + 2,1)
For I = 0 To 7 ' 8 peg levels - 0-7
Level = MAX(0,(I+D-7)) ' negative disk levels use empty peg (0)
For J = 1 To 3 ' 3 pegs
If Not (J = S) Then
Print TP$(0); ' empty peg
Else
Print TP$(Level); ' Empty peg if Level = 0
Next J
Print
Next I
For iI = 1 To 3: Print TP$(8);: Next: Print ' 3 wide base
Print " PIN 1 PIN 2 PIN 3" ' ID labeling
'''''''''THE GAME'''''''''
'set pin current relative levels of top disk down from top of pin
INIT:
PL(s) = 7-d
PL(e) = 7
PL(6-e-s) = 7
TOWER d,s,e
yx TopRow+12, 1
FINI:
Print "Play Again (Y,N) "; : GetKey A$ : Print A$
Print " I Hope you liked chalenging me to play the game!": End : EndIf
Print "Press Y or N - "; : GoTo FINI : EndIf
Pause 1000: GoTo HMD
End
Sub TOWER d,s,e
Local Nd,Ns,Ne 'Next values for d,s,e
If d <> 1 Then
Nd = d-1: Ns = s: Ne = 6-s-e
TOWER Nd,Ns,Ne
MOVE d,s,e
If d <> 1 Then
Ns = Ne: Ne = e
TOWER Nd,Ns,Ne
Sub MOVE d,s,e
SHOW_MOVE d,s,e ' Update the header line describing the current move
'Empty Current Pin Level & Move Up
yx (toprow + 3 + PL(s),15*(S-1)+1): Print TP$(0); 'clear old pin position
PL(s) = PL(s)+1 ' Adjuist Pin Level
yx (toprow,15*(S-1)+1): Print TP$(d); 'place pin above to move sideways
Pause Delay
'Clear Position & move Across
yx (toprow,15*(s-1)+1): Print TP$(9); 'erase current disk position
' Do long move in two steps; comment out the whole if structure to speed up
If Abs(s-e)=2 Then ' is this a long move?
dir = Sgn(e-s) 'which way?
'place disk in intermediate position
yx (toprow,15*(e-dir-1)+1): Print TP$(d);
Pause Delay ' let disk settle
'erase disk from intermediate position
yx (toprow,15*(s+dir-1)+1): Print TP$(9);
' Place Disk above destination pin
yx (toprow,15*(e-1)+1): Print TP$(d);
Pause Delay
'Clear position and Place Disk
yx (toprow,15*(e-1)+1): Print TP$(9); 'Clear disk from top
yx (toprow + 2 + PL(e),15*(e-1)+1): Print TP$(d); 'Place disk at end
PL(e) = PL(e)-1 ' Adjuist Pin Level compensate pin level for new disk
Pause Delay
''''''Cursor Control Subrouines''''''
Sub CU n ' UP
Print Chr$(27)+"["+Str$(n)+"A";
Sub CD n ' Down
Print Chr$(27)+"["+Str$(n)+"B";
Sub CR n ' Right (This is the only one I used once I wrote Sub YX)
Print Chr$(27)+"["+Str$(n)+"C";
Sub CL n ' Left
Print Chr$(27)+"["+Str$(n)+"D";
Sub YX n, m ' Move cursor to Y,X - (VT100 is 1,1 based
Local s$
Print Chr$(27)+"["+Str$(n)+";"+Str$(m)+"H";
Sub HOME ' Equivalent to YX 1,1
Print Chr$(27)+"[1;1H";
Sub ClearScreen
Print Chr$(27)+"[2J";
'''SIMPLE FUNCTIONS'''
Sub dS S 'Display Numeric String and leave cursor where it stops.
Print Str$(S); 'Print Char Data - don't use automatic space padding
Sub GetDig D
GD:
D$ = Inkey$
If (d$<"0") Or (d$>"9") Then GoTo GD
D = Asc(d$)-48
Sub GetKey A$
GK:
A$ = Inkey$
If (A$ >= " ") And (A$ <= "z") Then Exit Sub
'If (a$ = "Y") Or (a$ = "y") Or (a$ = "N") Or (a$ = "n") Then Exit Sub
GoTo GK
Function MAX(a,b) 'self explained
If a>= b Then: MAX=a:Else: MAX=b: EndIf
End Function
Posted: 01:08pm 04 Aug 2014
It reminds me of my Microbee days (Z80)
The reason for MMEdit failing was I had not implemented esc[nC - move cursor right.
It still shouldn't crash the way it did!
That will be fixed later on today.
TeraTerm is still much better (and always will be better) than MMEdit for VT100 use.
hwholmes
Posted: 02:18pm 04 Aug 2014
Yes Jim
There was a time when I had memorized the Z80 Octal code - it made more sense in octal than it did in hex!
Bert
Posted: 03:19pm 04 Aug 2014
It runs OK on V3.4.18 but I still admit that TerTerm is better.
