Local Time 08:05 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Measuring frequency on Micromite/maximite
OA47
Posted: 12:05am 25 Jul 2014
What are the limitations to measuring frequency on the micromite/maximite?
The only specs I can see in the documentation is the frequency range.
Specs I would like to know are:
What duration does the frequency need to be presented to the chip to be sampled and what is the minimum amplitude that is needed?Edited by Graeme Meager 2014-07-26
Posted: 12:13am 25 Jul 2014
Sampling is done once a second to the signal needs to be there for a second (I hope to add different sampling times in the future). The the signal needs to be TTL levels for a normal input as documented in the manual.
OA47
Posted: 12:16am 25 Jul 2014
Thanks Geoff, That information explains a lot. Hope you are enjoying your travels.
Best regards
GM
G8JCF
Posted: 05:01pm 25 Jul 2014
@Graeme Meager
The PIC32 clock on a uMite is NOT an xtal, so the accuracy of the frequency measurement must be necessarily limited.
On a Maximite, which has a crystal, the accuracy should be much, much better. Ideally some means of calibrating the clock should be implemented in your s/w (for the Maximite).
Since the clock on the uMite is in effect an RC network, its temperature sensitivity would make calibration a hopeless task IMHO.
So in sum, if your want to measure low frequencies (ie without a pre-scaler), and can accept loss of accuracy, then using the inbuilt RC clock of the uMite would be acceptable. If, however, U want Frequency Counter performance, then you MUST use the Maxi/Mini-mite, IMHO.
73
Peter
The only Konstant is Change
Posted: 06:31pm 25 Jul 2014
AS far as I could tell, once the pin is set to 'frequency' the micromite does a background count and every second, updates a register. Whenever you request a frequency reading, the most recent register value is returned.
As well as taking a full second to do the count, the value returned could be as 'old' as just under one second.
This is evident if you do a read just after setting the port state.
I find the frequency reading good for things that change slowly but not a lot of use for rapid changes.
Posted: 05:44am 26 Jul 2014
a useful 'enhancement' for functions that update in the background is an 'updated' flag that is set whenever the measured value is updated and cleared whenever the value is read out by the user program.
this could be implemented as something like a set of variables called MM.PINnnUD, where nn is the pin number from 01 up to 28. perhaps something for the next revision of mmbasic?
rob :-)
Posted: 06:27am 26 Jul 2014
  robert.rozee said   a useful 'enhancement' for functions that update in the background is an 'updated' flag that is set whenever the measured value is updated and cleared whenever the value is read out by the user program.
That sounds like a great idea, I will add it to the list for further investigation.
