Forum Index : Microcontroller and PC projects : CRC16 Checksum MMBasic
| edu001 Regular Member Joined: 14/07/2014 Location: United KingdomPosts: 82 |
Hi I need to to a CRC16 Checksum calculation on my output string in MMBasic Can someone point me in the right direction, I have searched and cannot find any reference to this at all Thanks |
| halldave Senior Member Joined: 04/05/2014 Location: AustraliaPosts: 121 |
ok found some code needs to be converted DEFINT A-Z DECLARE SUB CRC16 (Byte%) DIM SHARED TableLow(0 TO 255) DIM SHARED TableHi(0 TO 255) CLS FOR I = 0 TO 255 ' Initialize the lookup tables READ TableLow(I) NEXT I FOR I = 0 TO 255 READ TableHi(I) NEXT I ' *************************** ' just a few lines for test ' *************************** Lo = 0: Hi = 0 'Initialize CRC to 00 00 (start new) T! = TIMER FOR Byte = 1 TO 30000 'Calc CRC for 30000 characters Char = Byte MOD 256 'Get character CRC16 Char 'Calc into CRC NEXT Byte PRINT TIMER - T! 'Print how long it took ' Were done Hi & Lo contain the result ' Hi = High byte of 16 bit CRC ' Lo = Low byte of 16 bit CRC END DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H00,&HC1,&H81,&H40,&H01,&HC0,&H80,&H41 DATA &H01,&HC0,&H80,&H41,&H00,&HC1,&H81,&H40 ' DATA &H00,&HC0,&HC1,&H01,&HC3,&H03,&H02,&HC2 DATA &HC6,&H06,&H07,&HC7,&H05,&HC5,&HC4,&H04 DATA &HCC,&H0C,&H0D,&HCD,&H0F,&HCF,&HCE,&H0E DATA &H0A,&HCA,&HCB,&H0B,&HC9,&H09,&H08,&HC8 DATA &HD8,&H18,&H19,&HD9,&H1B,&HDB,&HDA,&H1A DATA &H1E,&HDE,&HDF,&H1F,&HDD,&H1D,&H1C,&HDC DATA &H14,&HD4,&HD5,&H15,&HD7,&H17,&H16,&HD6 DATA &HD2,&H12,&H13,&HD3,&H11,&HD1,&HD0,&H10 DATA &HF0,&H30,&H31,&HF1,&H33,&HF3,&HF2,&H32 DATA &H36,&HF6,&HF7,&H37,&HF5,&H35,&H34,&HF4 DATA &H3C,&HFC,&HFD,&H3D,&HFF,&H3F,&H3E,&HFE DATA &HFA,&H3A,&H3B,&HFB,&H39,&HF9,&HF8,&H38 DATA &H28,&HE8,&HE9,&H29,&HEB,&H2B,&H2A,&HEA DATA &HEE,&H2E,&H2F,&HEF,&H2D,&HED,&HEC,&H2C DATA &HE4,&H24,&H25,&HE5,&H27,&HE7,&HE6,&H26 DATA &H22,&HE2,&HE3,&H23,&HE1,&H21,&H20,&HE0 DATA &HA0,&H60,&H61,&HA1,&H63,&HA3,&HA2,&H62 DATA &H66,&HA6,&HA7,&H67,&HA5,&H65,&H64,&HA4 DATA &H6C,&HAC,&HAD,&H6D,&HAF,&H6F,&H6E,&HAE DATA &HAA,&H6A,&H6B,&HAB,&H69,&HA9,&HA8,&H68 DATA &H78,&HB8,&HB9,&H79,&HBB,&H7B,&H7A,&HBA DATA &HBE,&H7E,&H7F,&HBF,&H7D,&HBD,&HBC,&H7C DATA &HB4,&H74,&H75,&HB5,&H77,&HB7,&HB6,&H76 DATA &H72,&HB2,&HB3,&H73,&HB1,&H71,&H70,&HB0 DATA &H50,&H90,&H91,&H51,&H93,&H53,&H52,&H92 DATA &H96,&H56,&H57,&H97,&H55,&H95,&H94,&H54 DATA &H9C,&H5C,&H5D,&H9D,&H5F,&H9F,&H9E,&H5E DATA &H5A,&H9A,&H9B,&H5B,&H99,&H59,&H58,&H98 DATA &H88,&H48,&H49,&H89,&H4B,&H8B,&H8A,&H4A DATA &H4E,&H8E,&H8F,&H4F,&H8D,&H4D,&H4C,&H8C DATA &H44,&H84,&H85,&H45,&H87,&H47,&H46,&H86 DATA &H82,&H42,&H43,&H83,&H41,&H81,&H80,&H40 ' SUB CRC16 (Byte) SHARED Hi, Lo Temp = Byte XOR Lo Lo = TableLow(Temp) XOR Hi Hi = TableHi(Temp) END SUB |
Thanks for the reply I really did not want to use tables that method is quite slow, Im sure someone must have done this |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6630 |
The table method is ofter a lot quicker than calculations. This is a method I have used (but not in MM Basic). Procedure.l calcCRC(*LineBuffer, PktSize.l) Protected i.l, j.l, CRC.l CRC = 0 For i = 0 To PktSize-1 CRC= CRC ! (PeekA(*LineBuffer+i) << 8) For j = 1 To 8 If (CRC & $8000) CRC = (CRC << 1) ! $1021 Else CRC = CRC << 1 EndIf CRC = CRC & $FFFF Next j Next i ProcedureReturn CRC EndProcedure One big problem is there are a number of CRC16 methods to chose from. You do need an example string and CRC that your device needs to make sure that you are using the correct one. Jim VK7JH MMedit |
A table is usually just to speed things up - typical trade-off speed vs space. If speed doesn't matter then a short loop is usually the alternative (but may be too slow in MMBasic). IIRC, there are multiple 16-bit CRCs but only one known as CRC-16. (edit: haha, not as such! see wikipedia etc) Be sure to get the initial value right (often all 1s or 0s) as all others flow from it. John |
Thanks for the reply's the one I am after is CRC16_CCITT TassyJim what did you use that in |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1160 |
I need a CRC-Check too! I found this code in an old thread: Function CalcolaCRC (buf() As Byte, Nbyte As Integer) As Integer
Dim i As Integer Dim j As Integer Dim wCrc As Integer Const CRC_PRESET = &HFFFF Const CRC_POLYNOM = &H8408 wCrc = CRC_PRESET For i = 0 To Nbyte - 1 wCrc = wCrc Xor buf(i) For j = 0 To 7 If wCrc And 1 Then wCrc = ((Int(wCrc / 2) And &H7FFF) Xor CRC_POLYNOM) Else wCrc = Int(wCrc / 2) And &H7FFF End If Next Next CalcolaCRC = wCrc End Function Can anybody test if this code works on Maximite/Micromite? I think it needs only a small adaption. (I am not able to check if this code works correct...) Thanks! Frank |
| memberx Newbie Joined: 20/04/2012 Location: AustraliaPosts: 24 |
I have a SUB code for 16 Bit CRC calculation that returns CRC as Low and High Byte. Tested on Maximite for specific application. What is your application? |
I want to use the µMite as I2C-slave and must guarantee that the transmitted data is not corrupt. Frank |
memberx Could you could pm me regarding your code Thanks |
