Local Time 06:59 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CHDIR command on full-size MM...
Posted: 11:17pm 21 Jul 2014
Hi folks.
According to the manual, page 25, it says the syntax is CHDIR dir$ where dir$ is the directory you want to change into.
I can't make this work.
I have a directory on the SD card called DATABASE
If I try the likes of CHDIR "B:\DATABASE" no error is returned, but I am still in the current directory.
If I try the likes of CHDIR "B:\DATABASE\" no error is returned, but I am still in the current directory.
If I try the likes of CHDIR "DATABASE" I DO get an error(can't find or create directory), but I am still in the current directory.
What am I doing wrong? Manual has no more specifics.....
EDIT: Found out the problem - leave off the drive spec: CHDIR "\DATABASE" works.
Nevermind...Edited by Grogster 2014-07-23
BobDevries
Posted: 12:05am 22 Jul 2014
Grogster,
I believe that this was covered previously. I think in conversation with Nick Marentes.
I can't remember off hand what the solution is, but I seem to remember it being somewhat like the DOS system, where you need to change the DISK first (i.e. B:) and then CHDIR on the disk where the target sub-directory lives.
[edit] just tried it with DOS-MMBasic. It is just as I suspected:
Change the drive first:
B:
Then the directory:
CHDIR "database"
Regards, Bob Devries
Dalby, QLD, Australia
Edited by BobDevries 2014-07-23
Bob Devries
