Local Time 06:12 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : TFT maximite : how to center e character?
f1fco
Posted: 10:08am 15 Jul 2014
is it a means to center a single character in a TOUCH button on a TFT Maximite ?
and change the size of a single character in a button ?
Pierre, from France
73s de F1FCO
atmega8
Posted: 10:39am 15 Jul 2014
Don't understand your Problem?
Please describe it again with other words.
psergiu
Posted: 10:52am 15 Jul 2014
If possible, attach a picture with the issue you have.
f1fco
Posted: 11:08am 15 Jul 2014
how to attach a picture ?
a little code :
CLS
TOUCH SIZE 35,35
TOUCH CREATE 0,100,100,"A",1,B
DO
LOOP
you can the the char "A" is not in the center of the square, but on the left side...
try different size of touch is the same problem
its seems it was 2 chars (the A and other invisible char)
I want to create a small DTMF keyboard with 16 touchs (0 to 9,*,#,A,B,C,D)
Pierre
73s de F1FCO
f1fco
Posted: 11:09am 15 Jul 2014
typing error
you can see the char "A" is not in the center of the square, but on the left side...
73s de F1FCO
OA47
Posted: 12:20pm 15 Jul 2014
  f1fco said   typing error
Without seeing a picture, could you label the square with a space then letter A such as " A" to center the label?
f1fco
Posted: 11:35am 16 Jul 2014
I try you suggestion : " A"
and the A is on the right side of the square, not center !!!
a possibility is to write "A" with the commands :
FONT 2
PRINT @(112,109,5) "A"
and the "A" is (exactly) in the center of the square
but its a "loud" code
Pierre
73s de F1FCO
