Local Time 05:28 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Magic switch board for pic18f45k22
tomersonn11
Posted: 04:17am 07 Jul 2014
Hi everyone,
I'm trying to do a verison of mine to the magic switch board and since i'm new in this business,i would appreciate your help.
What i'm trying to do here is to send the "BUTTONS_ARRAY" after the learning mode in the "main" to the "BUTTONS_ARRAY_REPLAY" function and the output from this function to the "LEDS_ARRAY_REPLAY". Unfortunately it doesn't work. Can someone able to help me with this?
this is the code (for PIC18F45K22, mikro c version 6):
// Magic switch board for pic18k45f22
short number,state,tmp=0;
int i,j;
int LEDS_ARRAY[4]={17,17,17,17}; // Array that holds the lighting sequence of LATC
int BUTTONS_ARRAY[4]={17,17,17,17}; // Array that holds the lighting sequence of LATB
int flag_0=0, flag_1=0, flag_2=0, flag_3=0;
sbit red_BUTTON at LATB0_BIT;
sbit green_BUTTON at LATB1_BIT;
sbit yellow_BUTTON at LATB2_BIT;
sbit blue_BUTTON at LATB3_BIT;
sbit red_LED at LATC0_BIT;
sbit green_LED at LATC1_BIT;
sbit yellow_LED at LATC2_BIT;
sbit blue_LED at LATC3_BIT;
void Light(short number ) // Function that lights up LATC during the learning
switch(number)
case 1:
red_LED=1;
yellow_LED=green_LED=blue_LED=0;
LEDS_ARRAY[0]=1;
break;
case 2:
red_LED=green_LED=1;
yellow_LED=blue_LED=0;
LEDS_ARRAY[1]=2;
break;
case 3:
red_LED=green_LED=yellow_LED=1;
blue_LED=0;
LEDS_ARRAY[2]=3;
break;
case 4:
red_LED=green_LED=yellow_LED=blue_LED=1;
LEDS_ARRAY[3]=4;
break;
} // End of void Light function
short CountBit(short num) // Function that converts binary number to decimal number
short b,c;
for (b=0; num != 0; num = num >> 1)
if (num &1)
b++;
return b;
void LEDS_ARRAY_REPLAY ( int i)
if (i==0)
red_LED=1;
if (i==1)
green_LED=1;
if (i==2)
yellow_LED=1;
if (i==3)
blue_LED=1;
int BUTTONS_ARRAY_REPLAY (int BUTTONS_ARRAY[])//
while (1)
if (red_BUTTON==1)
tmp=1;
if (green_BUTTON==1)
tmp=2;
if(yellow_BUTTON==1)
tmp=3;
if (blue_BUTTON==1)
tmp=4;
for (i=0;i<=3;i++)
if (tmp==BUTTONS_ARRAY)
return i;
void main()
ANSELC=0;
ANSELB=0;
TRISC=0;
LATC=0;
number=LATB&0X0F;
while(1)
{ int i=0;
while (i<=3) // The learning stage
if (flag_0==0)
if (LATB0_BIT==1)
BUTTONS_ARRAY=1;
flag_0=1;
i++;
if (flag_1==0)
if (LATB1_BIT==1)
BUTTONS_ARRAY=2;
flag_1=1;
i++;
if (flag_2==0)
if (LATB2_BIT==1)
BUTTONS_ARRAY=3;
flag_2=1;
i++;
if (flag_3==0)
if (LATB3_BIT==1)
BUTTONS_ARRAY=4;
flag_3=1;
i++;
number=LATB&0X0F;
number=CountBit(number);
Light(number);
}// End of learning stage
Delay_ms(500);
LATC=0;
LATB=0;
BUTTONS_ARRAY_REPLAY (BUTTONS_ARRAY);
LEDS_ARRAY_REPLAY (i);
}if (LATB==0)
red_LED==green_LED==yellow_LED==blue_LED==0;
akashh
Posted: 04:58am 07 Jul 2014
I didn't get too far into your code but I think you would want to use pointers. Pass a pointer to your array of integers with int*arr in your function definition.
You can then refer to the various elements like this: arr[0], arr[1], etc.
I am not exactly sure whether that was your question?
tomersonn11
Posted: 05:10am 08 Jul 2014
Thanks for the help i found the problem and fixed it. I have another problem now, is it ok to use definition like this one- (LATB0_BIT) at pic18f45k22?
