Local Time 05:28 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic Subroutines
viscomjim
Posted: 01:21pm 30 Jun 2014
I don't know why I have a mental block on this but I hope someone can tell me the difference...
When would I use this...
IF A = 1 THEN GOSUB THISONE
SUB THISONE
P = A + 5
END SUB
or this
IF A = 1 THEN THATONE
THATONE:
P = A + 5
RETURN
When would I use END SUB and when would I use RETURN?
Posted: 01:26pm 30 Jun 2014
I used to be the biggest GOSUB fan, but have dropped all GOSUB's now for SUB's.
What I really like about a defined sub or function, is that you can pass variables to the sub. I guess you could do the same with a GOSUB, but define your variables first, then call the GOSUB, but the SUB or FUNCTION way is much neater - that's one main reason I like them.
It does tend to be a personal choice, to some extent, and you could reasonably assume that GOSUB/RETURN was the old BASIC way of doing subs, and SUB/END SUB etc is the modern BASIC way of doing things.
Both your examples would work.
EDIT: No, the first example would not work, as you have an END SUB for a GOSUB, which is confusing the two. You need END SUB on the first example. Actually, I would need to check that one, as it MIGHT work(as a SUB and GOSUB are both subroutines, and RETURN and END SUB both do the same kind of thing), but I would expect not.
EDIT: I am confusing MYSELF now!!!! I will wait for someone else to comment!Edited by Grogster 2014-07-01
Posted: 01:59pm 30 Jun 2014
For a start, you have them back to front.
Both the examples as given will cause an error.
This way works for either method:
a=1
IF A = 1 THEN GOSUB THatONE
print p
IF A = 1 THEN THisONE
print p
end
SUB THISONE
P = A + 5
END SUB
THATONE:
P = A + 6
RETURN
The choice of gosub/return
sub/end sub or
function/end function
is up to you.
subs and functions allow local variables and tend to make more 'portable' code.
Functions are my preferred choice provided I only want to return one value.
palcal
Posted: 02:06pm 30 Jun 2014
The way I see it your first example should be
THISONE:
P = A+5
RETURN
and the new way
Sub THATONE
P = A+5
EndSub
Paul.
viscomjim
Posted: 02:41pm 30 Jun 2014
Thanks for the replies....
I guess I assumed gosub would work with sub, end sub. But now I get it. GOSUB works with LABLE: RETURN.
I was going over the meter clock code from Jman (which is really awesome code) and noticed he used both methods throughout the program, but I cannot see why one was used over the other in any of part of the code. Does one have a benefit over the other?
viscomjim
Posted: 02:51pm 30 Jun 2014
Towards the end of the meter clock code...
' Convert to Hex
Sub BCDtoHex TempDec
hex = Fix(tempdec / 10) * 16
hex = hex Or ((tempdec / 10) - (Fix(tempdec / 10))) * 10
Return
ReadSettings:
i2caddr = &H50 ' 24c32 address
I2C Open 100,100
I2C Write i2caddr, 0,2,0,0 '24C32 Start Location
Pause 20
I2C Read i2caddr, 0,1,Brightness
I2C Close
Return
The "Sub BCDtoHex TempDec" has a "Return" instead of a End Sub and the next one has
"ReadSettings:" with a Return, so I am getting confused now.
jman
Posted: 07:14pm 30 Jun 2014
  viscomjim said   Towards the end of the meter clock code...
' Convert to Hex
Return
I do believe you found a bug on my part
this should be a End Sub
I seem to have not updated the posted code (My code in the Meter Clock is correct)
The next one ReadSettings:
is a normal gosub so the return is correct
Jman
Posted: 08:45pm 30 Jun 2014
In my opinion the GOSUB/RETURN/IRETURN should be deprecated and never be used in newly written software.
It has only value for backward compatibility. Never use it.
paceman
Posted: 10:38pm 30 Jun 2014
That sounds like good advice TZ. Like viscomjim, I've tied myself up in the past with exactly this issue and never known exactly which way it should be used.
I remember trying to figure it out using the MMBasic Manual but the difference is not really spelled out there. I reckon it would be worth Geoff adding a small paragraph (with an example) to do that.
Greg
viscomjim
Posted: 01:37am 01 Jul 2014
Thank you for your help. It sounds like I should stick to SUB... END SUB.
viscomjim
Posted: 03:49pm 01 Jul 2014
Well, what do you know Jman,
This seems to work...
a=1
print p
print p
end
SUB THISONE
P = A + 5
RETURN
THATONE:
P = A + 6
RETURN
RETURN works for both of them.... This is what I get when run on uMite...
RUN
7
6
So your code seems to be ok with uMite.... This is probably why there is no problem with your code for the meterclock. All is well in uMite land.
Edited by viscomjim 2014-07-03
viscomjim
Posted: 03:58pm 01 Jul 2014
Weirdness... This works also....
a=1
print p
print p
end
SUB THISONE
P = A + 5
end sub
THATONE:
P = A + 6
end sub
When run on uMite I get...
RUN
7
6
Seems like they both work.... return and end sub!!!
Posted: 05:31pm 01 Jul 2014
They might work now but future versions of MMBasic might tighten up on the syntax.
I would strongly recommend sticking to the 'correct' forms.
viscomjim
Posted: 10:31pm 01 Jul 2014
So the "correct" form for subroutines is
If a = 1 then Thisone
code
end
sub Thisone
code
end sub
I noticed in the uMite manual, when Geoff is explaining local variables on page 29, he uses the lable: return type subroutine. Does this have anything to do with local variables perhaps?
