Forum Index : Microcontroller and PC projects : question on keyboard (or keys)
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
I want to use the CGKEYCHIP1 - PS/2 Keyboard Chip like this, here : http://www.circuitgizmos.com/products/cgkeychip1/cgkeychip1. shtml but HOW to make a keyboard ? with custom keys I want to write my own labels under the caps... to custom a little keyboard (10 to 20 keys) can you help me to found this keys ? thank you Pierre, from Nimes, south of France 73s de F1FCO |
the site is here : http://www.circuitgizmos.com/products/cgkeychip1/cgkeychip1. shtml 73s de F1FCO |
cgkeychip1. shtml !!! erase the space between dot and shtml 73s de F1FCO |
Pierre Use the hyperlink button to add links. It is the 4th button from the left on the toolbar. Bob http://www.circuitgizmos.com/products/cgkeychip1/cgkeychip1. shtml |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1160 |
Hi Pierre, take a look on my Keyboardemulator It works very fine on PS/2 and you can generate ANY keystroke!!! (There is a HT82K628A from HOLTEK available which can only PS/2 which doesn't need an quartz... - it's a very simple circuit!!!) Frank |
I used in the past this Button:
You can open it and you can put any (laser) printed paper (with transparent foil above) instead of the original plate in it. Frank |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10074 |
The CG keyboard chip is for use with the MaxiMite series of computers - it will not function as a keyboard if you connect it to a PC or other full-size computer. CG has tested that, and a PC will not respond to this chip as a keyboard, as it is not a true keyboard controller, but an emulator. This works fine on the MM, but just don't expect to be able to plug this into a PC... @ Frank-N-Furter - I have the 628A's, that don't need the crystal, and these are the ones I could not make work. I might have to try again....Smoke makes things work. When the smoke gets out, it stops! |
Hi Grogster, I have no experience with the HT82K628A, I used only the HT82K629A (and this one works very fine). Did you used the correct value for the oscillator resistor (58,3KOhm - I think the timing of the oscillator is very important) and did you used a FERRIT on VDD? I would try to connect the resistor on the µC-side of the FERRIT OR on the power side... I hadn't any problems with the HT82K629A on USB AND PS/2... Frank |
Hi there. I tried to get as close to the 58k3 as possible, but perhaps I should have used a resistor and a trimmer, and set that to exactly 58k3 before putting the chip in....(i did not do THAT)
I might have another play with these chips, as I have nine more....
Yes, I did use a ferrite bead on VCC as per the datasheet. EDIT: Just had a quick look at my old attempt - I used a 56k and 2k2 metal-film 1% resitor in series, giving a total of 58k2, which I thought would have been close enough - perhaps not? I will see if I can find the old prototype PCB, and I could always hack an extra 100-ohm 1% resistor in there, and see if we get a response. Smoke makes things work. When the smoke gets out, it stops! |
thank you Frank for photo and link of the buttons, but item is out of stock I seach for custom buttom to use it with a maximite via a CG keyboard chip, not with a PC !!! Pierre 73s de F1FCO |
Lovely - that's nice to know. At least it should work fine then.Smoke makes things work. When the smoke gets out, it stops! |
Hi Pierre, you should get the Buttons from: REICHELT MOUSER or DIGIKEY Take a search to "Schurter" "1241.1100.7093" on the WEB Frank |
thank you for answer also I search for "old" DIGITAST keys at low prices... 73s from F1FCO, Pierre from Nimes, south of France 73s de F1FCO |
