Forum Index : Microcontroller and PC projects : question about MM.VER
| f1fco Senior Member Joined: 18/03/2012 Location: FrancePosts: 155 |
hello to all... I use the 4.5 version of Maximite and Micromite the command MM.VER return 4.05 is it right or a bug ? sorry if the question (and answer) was already put and sorry also for my (very) bad english Pierre, F1FCO, from NIMES, south of France 73s de F1FCO |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6629 |
That is correct. Done that way to allow for versions such as 4.12 4.0502 would be V4.5B Jim VK7JH MMedit |
hi Jim, thank you for answer I am "reassured" 73s from F1FCO 73s de F1FCO |
