Local Time 03:25 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite - detect pin to GND?
Modena
Posted: 01:31am 18 Jun 2014
Hey all, is there a way to detect when a wire/circuit connected to a Micromite I/O pin is sent to ground?
Ben
Posted: 01:35am 18 Jun 2014
If it's set as an input, just read it. If it's an output then it better be open drain or may damage the chip!
If you need to know it's Gnd rather than a logic low, that's a bit more effort but try analog.
JohnEdited by JohnS 2014-06-19
Modena
Posted: 01:48am 18 Jun 2014
thanks for the reply John, but surely if the pin is grounded it will read 0v, and if the circuit is open it will also read 0v?
Ben
Goeytex
Posted: 02:34am 18 Jun 2014
  Modena said   thanks for the reply John, but surely if the pin is grounded it will read 0v, and if the circuit is open it will also read 0v?
Ben
Not necessarily. Ground may be defined a physical point used as reference for voltage levels.
A pin being grounded means it is physically connected to the ground reference point and not necessarily that it is taken "low" by an external device. So if a pin is grounded and the meter is referenced to ground, it will read 0 volts.
An open circuit, meaning absolutely nothing is connected to the Pin, will not necessarily read OV.
If the pin is an input and pull ups are NOT enabled, it will be floating and in an indeterminate high impedance state. There may or may not be voltage present. But the impedance of the meter might be enough to drive the pin down to near 0 volts when taking a reading. A high impedance meter or scope may read a voltage anywhere from 0V to near Vdd.
If the pin is an input and pullups ARE enabled, then with nothing connected to the pin, it will read the supply voltage minus a few hundred millivolts.
Posted: 02:53am 18 Jun 2014
Don't have floating (*) pins! They sometimes read as 0 and sometimes as 1, and may flip between those or latch up in some nasty way.
(*) implies input pins
Posted: 05:41am 18 Jun 2014
  Modena said   Hey all, is there a way to detect when a wire/circuit connected to a Micromite I/O pin is sent to ground?
Ben
the simple answer to your question:
yes. connect a 10k resistor from your pin to 3v3. this will ensure that reading the pin normally returns a '1'. if you now connect the pin to ground (0v) the pin will return '0'.
for example, the below code assumes you are using pin 2. 10k resistor from pin 2 to 3v3, and a switch from pin 2 to ground.
setpin 2, DIN
do
print pin(2)
pause 10
loop
rob :-)Edited by robert.rozee 2014-06-19
