Local Time 02:15 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : i2c simultaneously
viscomjim
Posted: 05:30am 29 May 2014
In the 4.5 manual it says that for I2C, the master and slave modes can be enabled simultaneously, so does this mean 2 uMites would have this type of code (different addresses of course) running and can be both a master and a slave at the same time just making sure that they are all timed correctly to talk to each other?
I2C OPEN 100,100
I2C SLAVE OPEN &34, 0, 0, WRITED, READD
DO
LOOP
READD
IRETURN
WRITED
IRETURN
I2C CLOSE
I2C SLAVE CLOSE
Posted: 09:05am 29 May 2014
Yeah, that is about right.
I would suggest to use the newer/better/clearer/fancier :) way of using a subroutine (It prevents code from accidentally entering a subroutine.) and change the order of it a little.
Like:
[code]
I2C OPEN 100,100
DO
LOOP
I2C CLOSE
I2C SLAVE CLOSE
SUB READD
END SUB
SUB WRITED
END SUB
[/code]
Edited by TZAdvantage 2014-05-30
viscomjim
Posted: 03:30am 30 May 2014
Thanks TZ! I will be trying this Master Slave idea once I get a better handle on I2C. So far with playing around, this is a great way of making simple inexpensive I2C devices when one is not well versed in programming pic chips using assembler.
