Local Time 01:14 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 2 Instances of MMEdit
viscomjim
Posted: 02:01pm 26 May 2014
Getting ready to play with 2 uMite setups to test some I2C stuff. I was going to use 2 laptops running mmedit but is it possible to run 2 on one machine? Both console coms will be done with ttl serial to usb.
Thanks again!
Posted: 04:52pm 26 May 2014
Sort of.
There is only one set of configuration data so there is a chance of the program getting confused.
You could make a 'portable' installation (from the file menu) and then the configuration is kept separate. Make sure that you make the portable copy somewhere that you have full write permission or Windows will get upset.
With the portable copy, all the data is in a folder up from the program folder instead of in the Windows 'local data' area.
The main drawback with the portable copy is there is no easy way to update the program. Every time I update MMEdit, you will have to make another portable copy.
Posted: 08:30pm 26 May 2014
Workaround on Linux would be to run each from a separate user account. (You may need an xhost command to allow it.)
It works because you can be logged in to as many different users as you like at the same time.
