Local Time 01:16 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEdit Protection Violation Error
Goeytex
Posted: 06:00pm 24 May 2014
Just tried to install MMedit (3.4.10) on Win7-64 SP1 (Compaq CQ60-615DX) and when it tries to start it throws the following error. Install fine on XP.
Any thoughts?
Error log timestamp 5/24/2014 22:49:53
The registers were:
EIP = 0x01ee020d
ESP = 0x0018fea8
EBP = 0x00000000Cq60
EAX = 0x08744444
EBX = 0xffffe001
ECX = 0x00000100
EDX = 0x0008e3c8
EDI = 0x00000001
ESI = 0x08744444
CS = 0x00000023
DS = 0x0000002b
ES = 0x0000002b
SS = 0x0000002b
End Registers
Message 1001:
a non-continuable protection violation has occurred. Check ERROR.LOG file.
Edited by Goeytex 2014-05-26
Posted: 06:18pm 24 May 2014
I run MMEdit happily on W7 both 32bit and 64 bit.
I hope that the following fixes the problem for you:
A non-continuable protection violation is Windows' way of protecting us from rouge software and to make life difficult for program developers.
Visa made the setting too tight but they relaxed things a bit for Windows7.
My W7 has the default setting and all is well but some PC suppliers had things set tight.
You can either change your settings or install MMedit into a folder that is NOT in 'Program Files'
Please check you DEP settings and if is not set to essential Windows programs only, that is the problem. If you want to leave it set for all programs you can add MMedit as an exception or go the other folder method.
The easiest way to find DEP is to search Windows Help for DEP.
DEP stands for Data Execution Prevention.
I did add a "manifest" which is supposed to stop this from happening but as you have seen, Windows wins the battle some times.
Goeytex
Posted: 09:46pm 24 May 2014
That solved it. First time I have had that happen with a program.
Thanks!
Posted: 10:05pm 24 May 2014
Glad it is working now.
The problem has something to do with Liberty Basic, the compiler I used for MMEdit.
The new version (when I eventually release it) is written in PureBasic which has a different set of problems to deal with.
