Local Time 01:16 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Duinomite with MPIDE
JohnL
Posted: 03:45pm 19 May 2014
I have successfully remapped pin assignment for Duinomite to be used with MPIDE.
I am looking for a MPIDE Bootloader that supports Duinomite Program Load button on RD8 port pin, or a source code for MPIDE Bootloader for PIC32MX795.
At the moment Fubarino bootloader works fine but Program Load button is on RE7 or D7 pin on Duinomite. So far cant find source code for this bootloader to modify.
MPIDE has give Duinomite a new lease on life with unparalleled performance and lots of existing Arduino software and hardware.
JTR0701
Posted: 06:18pm 19 May 2014
For the source code try here: https://github.com/chipKIT32/PIC32-avrdude-bootloader/tree/m aster/bootloaders
JohnL
Posted: 09:41pm 19 May 2014
Thanks JTR0701,
  Quote  For the source code try here: https://github.com/chipKIT32/PIC32-avrdude-bootloader/tree/m aster/bootloaders
Includes a comprehensive list of PIC32 processors.
Unfortunately, I don't have PRO XC32 compiler for full optimization.
Will see if I can get someone with PRO XC32 to recompile with program/upload button and LEDs port changes.
#elif defined(_BOARD_FUBARINO_SD_512K_USB_) // 32MX795F512H, Microchip version (v1.5)
// Boot LED
#define BLedLat E // change to B
#define BLedBit 5 // change to 12 OR 15 for yellow or green LED.
// Virtual program button
#define VPBntLat E // change to D
#define VPBntBit 7 // change to 8
// Program button
#define PBntPort E // change to D
#define PBntBit 7 // change to 8
SOLVED
MPIDE Bootloader for PIC32-T795 works perfectly.
https://www.olimex.com/Products/Duino/PIC32/PIC32-T795/open- source-hardware
Time for me to place Basic Interpreter back in the museum.
Edited by JohnL 2014-05-21
