Local Time 01:16 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RGB LED and PWM output
viscomjim
Posted: 09:25am 19 May 2014
Was asked to make an RGB controller for some RGB leds for a friend. Immediately I thought of using the uMite for this. Upon reading the manual for 4.5 I realized that there are only 2 pwm outputs. I was going to use the pwm outs to drive fets for higher current handling. However with only 2 pwm outs i seem to have hit a wall. Does anyone know if it is somehow feasible to use the servo outs to drive the fets for this type of thing?
Thanks!!!!!!
PicFan
Posted: 09:53am 19 May 2014
Hello,
i think the uMite have 2 Generators and 5 PWM Outputs. Gen.1 Output 1A,1B, 1C and Gen.2 Output 2A, 2B. I control a high power Led with RGB and White with the uMite 28p and IRF-7471 MOSFET as Driver.
viscomjim
Posted: 11:50am 19 May 2014
Hi PicFan,
That sounds perfect! Would you care to share some code so we can get an idea?
Thanks!!!!
viscomjim
Posted: 01:05pm 19 May 2014
I looked at the manual (should have done that first duh!) and see that indeed the freq. and pwm is easily controlled using the servo deal. PicFan, what freq. are you running for your rgb setup?
PicFan
Posted: 10:08pm 19 May 2014
I have the best results with 2500Hz.
PWM 1,2500,r,g,b
