Local Time 00:17 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite - a comfortable pair of shoes
halldave
Posted: 10:49pm 04 May 2014
I've tried Arduino, Raspberry Pi, Xcode, and even built the colour Maximite just to have a play,
I'm old, and feel comfortable in the old Microsoft Basic I learnt on the Dick Smith System 80
Geoff has reinvigorated that for me and given clever and smart access to all new features, I now have the best of both worlds and am busy designing some PCB layouts.
Has anyone had any success with Ethernet interfacing if so any example boards would be a help as i'd like some form of internet functionality on my next project
Well done and thanks Geoff
regards
David Hall
Posted: 03:40am 05 May 2014
Hi David,
I have successfully used this module with a MaxiMite to create a webserver issuing web pages showing temperature captured on a one-wire DS18B20 temp sensor.
Also used iButton reader to read and log unique user ids (iButton mounted on staff pass-cards) and then viewed the log remotely.
I was just playing at the time to see how easy it was (and it was surprisingly easy to get working quickly). Unfortunately I didn't document anything but it is a project I will be offering in the future.
Take a look at the datasheet for the above module. It is technically easy to use and code. Any UART-to-Ethernet module will simplify what you are trying to do so google this with your favorite/local supplier and you should find something.
Keep us informed how you get on . . .
Phil
atmega8
Posted: 05:36am 05 May 2014
Wiznet, easy to interface....
Sample Basic code
halldave
Posted: 10:50am 05 May 2014
Thankyou for the leads, ill check both of them out, after a quick look both seam very workable
regards
David
