Local Time 00:16 26 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Clock crystal
vasi
Posted: 03:33am 04 May 2014
Hi guys,
Can anyone tell me if I can use a miniature (those are smaller that what we buy on online stores) crystal from a regular digital clock for a PCF8583 RTC? Are those standard, or there are different frequencies?
Vasi
Elvish name: Mablung Miriel
Beyound Arduino Lang
Posted: 10:01am 04 May 2014
Vasi,
You could try to scavenge one from an old (or cheap LCD/ electronic wrist watch)
vasi
Posted: 10:27am 04 May 2014
Thanks Mick, almost exactly what I asked (should have said watch ) - so, it is good. I scavenged one and soldered on the board. My board is almost ready, then I will make some tests before posting about it.
Vasi
atmega8
Posted: 11:46am 04 May 2014
Reichelt.de
Pollin.de,
Cylindric, 2x5mm, approx.
Some Cents
Posted: 08:48pm 04 May 2014
Sorry Vasi,
Yes I thought you wanted a super small 32khz `rock'.. Yes saying watch would have made me see what you were really asking.
As far as I know the 32kHz crystal is the only one (well 99.99%) that is used in clocks.
mick
vasi
Posted: 07:16am 09 May 2014
Thanks Mick, it works indeed. Is a little faster and definitely needs a trimer for adjustment. A temporary solution, good for testing and firmware development, but not for final application, as there is not much precision. But now I'm able to continue my work (I've finally ported the PCF8583 library from avr-gcc to JALv2).
