Local Time 22:36 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Add USB, 5V and 3.3V cheaply.
donmck
Posted: 04:43am 15 Apr 2014
Just spotted this post in "sci.electronics.design" newsgroup.
Add USB and 5 V and 3.3V power and felt it could be of interest to some members.
From Jan Panteltje (regular contributor to many user groups and Electronics Book Author)
http://panteltje.com/panteltje/jan/index.html
Cheapest way to add USB and 5 V and 3.3V power to a RS232 PIC project
Got some ebay USB To RS232 TTL PL2303HX Auto Converter Module Converter Adapter for arduino
ebay object: 360750555245
Module has 5V and 3.3 V out (from the USB power).
The PL2303 works 100% OK with Linux native drivers.
Just connect to RS232 in and RS232 out, and power,
and no need to write USB code, or get a special PIC, or bother about licenses,
or maxmin^h^him chips.
and all that at only 99 dollar cents a piece.
I just build one into an existing RS232 project, simplifies a lot of things.
Any terminal program or script can talk to it.
It is also a lot cheaper than external USB to RS232 adaptors (wut hte same chip!),
just solder the pins into your board.
# lsusb
Bus 005 Device 006: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
PS it has a red LED too, to show USB is connected.
Googled and found this at 99 cents (USD):
http://www.ebay.com/itm/360750555245#shpCntId
But does not ship to Australia.
But this one does at $1.47AUD
http://www.ebay.com.au/itm/USB-To-RS232-TTL-PL2303HX-Auto-Co nverter-Module-Converter-Adapter-For-arduino-/180953299346
Cheers Don...
https://www.dontronics.com
Posted: 06:09am 15 Apr 2014
Hey Don,
If you ever get the chance to go to China you will see row after row of massive warehouses full of these 'goodies'. I reckon any BSF member would have fun over there; and would easily be able to spend just $100 and buy a lifetime's supply of 'bits & pieces'.
So not a bad business these bulk Chinese sellers have. In the last 1 month the seller (your second link) has nearly 26,000 positive feedback scores. Assuming at least $1 per sale then thats not a bad $return$ in the month! And there is probably an equal number of buyers that don't rate the seller - another big handful of $$'s to add to this figure.
And do you think they bother about the 1% giving negative feedback!
All I would add is that if you do buy some of these 'cheapies', then buy several (not just one) and be prepared to throw a quantity away - still works out cheaper though than the 'genuine' thing!!
WW
akashh
Posted: 03:15pm 16 Apr 2014
I get lots of my samples and components from AliExpress , you can get anything and everything there, prices are very decent and I only once had a problem with one of the items which didn't function correctly. After complaining I got a full refund immediately. I highly recommend this to anyone who doesn't know it.
Akash
