Local Time 22:36 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MicroMite Beta 18
     Page 1 of 3
Frank N. Furter
Posted: 07:46pm 09 Apr 2014
it seems that a STRG+C within the first seconds erase the program (BETA 18, 44Pin with OPTION AUTORUN ON, OPTION LINES 35)???
My µMite is powered over a PL2303
Now I will test this behavior with another program on another µMite...
EDIT: I tested now with WhiteWizzards modules and I can't produce the effect.
EDIT2: Now I can't reproduce this behavior with my PL2303 µMite - what's going on?
I erased two times my program with CTRL+C at startup...
FrankEdited by Frank N. Furter 2014-04-11
Posted: 07:52pm 09 Apr 2014
What is STRG+C? Do you mean Control-C?
This is very strange behaviour indeed. It could be that the console Tx and Rx were accidentally shorted during power on - that would reset MMBasic and erase the program.
Frank N. Furter
Posted: 08:06pm 09 Apr 2014
Hi Geoff,
yes! I mean the Control-C (labeld with Strg on my keyboard).
But at the moment I can't reproduce the erasing!
I lost 2x my program...
Frank
Frank N. Furter
Posted: 08:20pm 09 Apr 2014
After my last reconnecting the PL2303 to my PC I getted a blue screen...
I tried the same procedure many times but I can't reproduce the problem again...
A physical connection of Rx and Tx is impossible (...and I don't lost my OPTION LINES 35) after this strange behavior - only my program was lost!
I will try again...
Frank
Frank N. Furter
Posted: 08:39pm 09 Apr 2014
Ok,
I flashed my PIC new, transfered my program, setted the options and started again with the same procedure as above BUT I DON'T LOST MY PROGRAM!
I hope it was a unique misbehavior of my MicroMite...
Sorry Geoff for the confusion...
Frank
OA47
Posted: 08:44pm 09 Apr 2014
I had a similar problem on earlier betas when I had the console RX and Tx reversed. Entered a Ctrl-C to break a running program and ended up clearing the program. Maybe a similar issue?
Frank N. Furter
Posted: 09:04pm 09 Apr 2014
My Rx and Tx connection is fixed but I had problems with my PC today (2 blue screens because Teraterm and/or PL2303 driver).
Is it maybe possible that the Prolific drives the input high as output (because of mailfunction)? This would this behaviour explain...
Frank
vk4tec
Posted: 09:11pm 09 Apr 2014
Been watching with interest about developments
What hardware are you working on ?
Release date ?
Andrew
Andrew Rich VK4TEC
www.tech-software.net
Posted: 09:20pm 09 Apr 2014
Frank,
I don't have a lot of confidence in the Prolific chips. There were a lot of clones about and the efforts to create drivers that worked with the genuine chips and not the clones seems to have caused problems.
Andrew,
The micromite will be released in the May issue of Silicon Chip.
Think of a 28 pin Picaxe running MMBasic.
vk4tec
Posted: 09:38pm 09 Apr 2014
What is a pic axe. ?
Andrew
Andrew Rich VK4TEC
Posted: 10:09pm 09 Apr 2014
Frank,
Along with TassyJim (and many others), I too don't have much confidence with the Prolific chips (previous posts have debated this but as I mentioned at the time - this kind of inconsistency is exactly why I steer clear of them!).
If you experience this again with the FTDI usb-to-uart such as used on my 44-pin MicroMite Module, then please do let us know the steps taken and I will recreate here to investigate!
Thanks . . .
Posted: 10:26pm 09 Apr 2014
  vk4tec said   What is a pic axe. ?
Andrew
http://www.picaxe.com/
Posted: 10:38pm 09 Apr 2014
The GENUINE Prolific 2302 seems to go fine, if you can find one, but as mentioned - there are so many 2302 clones out there now, and the drivers for the clones tend to be exceptionally flaky.
I argued this morning for about two hours with a cheap 2303 on a pager programmer cradle. This was embedded into the programmer itself - all there was, was the USB socket on the device.
I cracked it open, found the TXD and RXD, cut and isolated them, moved them to a socket on the case. Connect this to a 232 level corrector, hook to PC and it works like a charm WITHOUT any drivers needed, cos I am now using the native COM1 serial port.
I tell you - the 2302 clones can cause you so much trouble, I whole heartedly encourage you to find another brand of converter such as FDTI based UNLESS you can guarantee that you are using a genuine Prolific adaptor.
Greg Fordyce
Posted: 12:24am 10 Apr 2014
A few more small corrections for the manual.
Page 5 describes 44 pin chips but doesn't mention which 2 pins you lose access to if you use a USB enabled PIC32MX250.
  Quote  Similar to the 28 pin package there are versions rated at 40MHz and versions that support USB (with
the latter you loose access to two I/O pins which are reserved for USB functions).
Page 17, Measuring temperature heading, remove underlined words.
  Quote  Multiple sensors can be used but a separate
I/O pin and pullup resistor is required is required for each one.
Page 18, Micromite pin 2 not labelled on drawing.
Page 25, change pin "9" to 25
  Quote  In your BASIC program you would set the input as a digital input and use the PIN() function to get its level.
For example:
SETPIN 23, DIN
IF PIN(23) = 1 THEN PRINT “High”
The SETPIN command configures pin 9 as a digital input and the PIN() function will return the value of that
pin (the number 1 if the pin is high).
I've only got to page 30, might find a few more.
Greg
Frank N. Furter
Posted: 12:29am 10 Apr 2014
Hi Folks,
it should be a PL2303HXA (inside a cable) from Adafruit. I know that somebody hate the Prolific chips but i hadn't problem with this adapter... up to now...
Normaly I prefer the FTDI chips too (but colleagues in my last job had great problems with a unusual configuration where the chip doesn't do what in the datasheet was - but I didn't exactly which problem was)
The only "real" problem I know with the Prolific chips is with Win8 but I have Win7...
Frank
Posted: 01:05am 10 Apr 2014
  Frank N. Furter said   After my last reconnecting the PL2303 to my PC I getted a blue screen...
Frank
this is a common problem, caused by certain atmospheric conditions. fortunately, the solution is simple. take a blowtorch and, with the flame adjusted to a medium blue, heat up the prolific PL2303 chip until it starts to glow red (remember - blue flame, red chip). this will drive off excess smoke that has accumulated within the prolific chip. keep the heat on until no more smoke is produced.
your prolific chip has now been reset to it's factory default settings and will not cause you or anyone else any more problems. remember: blue flame, red chip, keep heat on until no more smoke.
with a little practice, this procedure can be applied to multiple PL2303 chips at the same time. it is considered best, by most sensible people, to treat all your PL2303 chips in this way immediately upon their arrival.
rob :-)
Posted: 01:11am 10 Apr 2014
I have a slight modification to Rob's method above as follows:
Keep the blue flame going even when chip glowing red, then keep it going until the chip goes up in smoke!
Then replace it with an FTDI chip
This will solve all your problems . . . .
Frank N. Furter
Posted: 01:25am 10 Apr 2014
...I think we should build a heatcontrol with a µMite for a controlled burning off...
Frank
Posted: 01:27am 10 Apr 2014
  Frank N. Furter said   ...I think we should build a heatcontrol with a µMite for a controlled burning off...
Frank
(just ensure you use a FTDI to debug it or it will never work)
Greg Fordyce
Posted: 02:12am 10 Apr 2014
Found another small typo on Page 61
  Quote  Example
I2C is ideally suited for communications between integrate circuits.
Should probably read "I2C is ideally suited for communications between integrated circuits."
Greg
     Page 1 of 3
