Local Time 21:41 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SETPIN "Incorrect syntax" problem...
Posted: 08:51pm 29 Mar 2014
Hi folks.
If I use the line:
SETPIN D3,6,ResetP
that works fine for enabling an interrupt on pin D3.
BUT, if I use the line:
SETPIN D3,0,ResetP
i get an invalid syntax error.
In the manual, page 34 under the SETPIN command, it says that if I use 0 for cfg, this should disable the interrupt - "0 - Not configured or inactive"
Any idea why this is not working?
Full-size colour MM, version 4.4
Edited by Grogster 2014-03-31
Posted: 09:35pm 29 Mar 2014
OK, looks like you don't need to specify the interrupt routine when you disable the pin.
SETPIN D3,0,ResetP throws an error, but SETPIN D3,0 does not, and still seems to work OK as far as disabling the interrupt on that pin.
Manual update perhaps?
