Local Time 21:40 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CLS missing on µMite
Frank N. Furter
Posted: 03:03am 27 Mar 2014
it would be nice to clean the entire (visible) screen on the VT100 terminal.
The good old "CLS" command doesn't work anymore...
I tried several VT100 commands as
Print Chr$(27);"[H"
Print Chr$(27);"[f"
Print Chr$(27);"[2J"
but I am not able to clean the entire screen! The first line will be always untouched and not deleted!
Did anybody have an idea?
(@Geoff: ...I think I remember that the CLS works on the MM on VGA, BAS *and* terminal window?)
Frank
Posted: 03:47am 27 Mar 2014
Hi Frank,
If you are using Tera Term, then under the 'Edit' menu there is an option to 'Clear Screen'. Does what it says on the tin!
Other console programs should have a similar feature.
There is little meaning in having any graphical control with a MicroMite (including CLS) when you think about it.
Let us know if this is a suitable solution for you!
Phil
Lou
Posted: 05:25am 27 Mar 2014
The CLS is handy when editing on chip, I also miss it. It was probably taken out for more room in the uMite for other features, maybe it will show up again on the 170 chip - only Geoff knows.
WW's work around works but you have to grab the mouse. A work around from the keyboard is F4 then ESC key from the command prompt, that will clear it.
LouEdited by Lou 2014-03-28
Frank N. Furter
Posted: 05:52am 27 Mar 2014
Hi White Wizzard,
you are right with the Teraterm option, but I need a CLS to print new values on the same position on the terminal window within a loop from the µMite program...
I think it should be possible with any Teraterm-VT100 command.
FrankEdited by Frank N. Furter 2014-03-28
Posted: 06:03am 27 Mar 2014
Hi Frank,
Not knowing exactly what you are doing, if this 'displayed' value is considered necessary, why not use a cheap LCD to display it?
The LCD concept is cheap, and reasonably well documented elsewhere on the forum.
Yes I fully appreciate that it can be very useful to display data in a fixed position on a console display (very much so for debugging purposes), but would you really design a MicroMite solution to display data on a console?
It would be very interesting to know more about you overall aim and what it is that you are 'building'.
Please share if you wish too . . .
Phil
psergiu
Posted: 07:42am 27 Mar 2014
Since you are using an external serial terminal, the "clear screen" function is handled by your terminal.
The official VT100 clear screen sequence is "<ESC> [ 2 J" so your Print Chr$(27);"[2J" should have cleared-it. This means your terminal software is not 100% DEC VT100 compatible.
A built-in CLS command will just print "<ESC> [ 2 J" and will also not work on your terminal software. Also for people using other terminal types (VT52, DOS-ANSI, 3270, HPTERM, TEK ...) different escape codes for CLS are needed. And i don't think Geoff can fit the whole TermInfo/TermCap database in there
So find a escape code that works on your particular terminal and make your own CLS.
See here for some useful escape codes: http://www.termsys.demon.co.uk/vtansi.htm
Posted: 08:35am 27 Mar 2014
Frank,
I can confirm that psergiu's method of using: Print Chr$(27);"[2J" works with TeraTerm.
Note that it clears the screen down to the current line. I guess you then need cursor positional control to place cursor at relevant location before printing your data.
Will look at the link psergiu provided and play a little more . . .
Posted: 09:03am 27 Mar 2014
Frank,
OK got it working nicely with a little test program (and no LCD required!!!)
x=0 ' used as a counter value that is displayed on the console window
Print Chr$(27)+"[2J"+Chr$(27)+"[3;6H"; ' Escape codes to clear screen & move cursor to Row 3; Column 6
Print Str$(x); ' Print value of counter at cursor location (set above)
x=x+1 ' inc counter
Pause 333 ' delay a bit
Loop ' and repeat . . .
Try the above and see if it works for you too !!
Phil
Posted: 01:24pm 27 Mar 2014
There is a little shortcut that you can use here, the elements of a PRINT statement will be joined together when printed if they are separated by just spaces or nothing.
So, you don't need the semicolon (;) or the plus (+) characters.
For example, using Phil's example above, this will also work:
Print Chr$(27) "[2J" Chr$(27) "[3;6H"; ' Escape codes to clear screen & move cursor to Row 3; Column 6
Posted: 01:38pm 27 Mar 2014
Thats worth knowing for the future
You're not wrong Geoff when you say its ' a LITTLE shortcut' !
Frank N. Furter
Posted: 09:45pm 27 Mar 2014
Thanks to White Wizzard, Psergiu and Geoff!!!
@ White Wizzard: I evaluate my ISL29023 lightsensor with my adapted program for µMite which I offered in this thread:
http://www.thebackshed.com/forum/forum_posts.asp?TID=6161&PN =1
You are right that a LCD is necessary for a finished gadget but for my tests I have only the sensor, 1 LED and a PL2303 on my µMite.
Thanks a lot to all for helping!
I tried it with >> Chr$(27)+"[2JChr$(27)+"[H << but I have forgotten the semicolon on the end!!!
...but with this little change my code print the values correct in the first line!!!
Print Chr$(27) "[2J" Chr$(27) "[H"; works very fine!!!
Frank
