Local Time 20:45 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Questions about MICROMITE
rentner111
Posted: 01:20pm 25 Mar 2014
1 in Micromite User Manual Ver 4.5 Beta 16 is on page 24 to read under INTERRUPTS: All I/O pins can be as configured to generate to interupt using setpin command ...... The schedule of the 44-pin connections but is not the INT function for all pins possible.
It also comes on this pins the error message that no Int function is possible.
2 Is it not possible to activate the pull-up function? This would save a lot of space on the layout, which is required by the now necessary pull-up resistors.
With thanks for an answer
Posted: 01:55pm 25 Mar 2014
Ah, ALL I/O pins is wrong (I will fix that). Only the pins marked INT can be used.
Yes, some way of implementing the on chip pullups and pulldowns is on my ToDo list but it will have to wait for a later release.
