Forum Index : Microcontroller and PC projects : Engineering format for MMBasic
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6629 |
Sometimes it is preferable to format numbers in either exponential or engineering formats This function does either. Engineering notation is exponential notation with the exponent alwas a multiple of 3 The function was written for the MicroMite and works but does not display a positive sign for the exponent on other versions of MMbasic. The three inputs are: number to format number of decimal places displayed engineering notation (anything other than zero = engineering), zero or omitted = standard exponential ' MicroMite
'format number in Engineering notation ' TassyJim 16 March 2014 main: input "Number to format";n print str$(n)+" "+StrE$(n, 3)+" "+StrE$(n, 3, 1) goto main function strE$(mx,p, eng) ' mx = number to format ' p = number of decinal places ' if eng is not zero, use engineering notation local px, sn$, x sn$=" " x=mx If x < 0 then sn$ = "-" x = x * -1 EndIf if x<>0 then ' zero is a special case px=int(Log(x)/ log(10)) if eng <> 0 then ' engineering notation - multiples of 3 px = int(px/3)*3 endif x=x*(10^-px) strE$ = sn$ + Str$(x, 0, p) + "e" + Str$(px,-1) else strE$ = sn$ + Str$(x, 0, p) endif end function The output: Number to format? 12345.678
12345.7 1.235e+4 12.346e+3 Jim VK7JH MMedit |
