Local Time 19:45 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite SPI
palcal
Posted: 10:38pm 04 Mar 2014
I was using a DTX2-2800C GPS from Dimitech with the MM and it worked OK. I have tried to convert the code to work with the Micromite but am having a problem, the GPS keeps returning a value of 255. SPI is fairly new to me so any help would be appreciated.
The code I am using is
Dim arg$(20)
SetPin 10,8:Pin(10) = 1
SPI OPEN 5000000, 3, 8
Pin(10) = 0
b=SPI(&h3b)
GPS:
GoSub GPS2
If arg$(0) = "GPRMC" Then 'GPRMC contains lat, lon
If arg$(2) = "A" Then 'A means locked to satellite
Lat = Val(Mid$(arg$(3), 3)) 'latitude in decimal
Lon = Val(Mid$(arg$(5), 4)) 'longitude in decimal
Print lat,lon
Pause 500
GoTo GPS
GPS2:
Do While Chr$(SPI(0))<> "$":Loop 'wait for the start
For i = 0 To 20
arg$(i) = "" 'clear ready for data
Do 'loops until specific exit
x$=Chr$(SPI(0)) 'get the character
If x$="," Then Exit 'new data field, increment i
If x$="*" Then Return 'we have all data so return
arg$(i) = arg$(i) + x$ 'add to the data
Loop 'loop back for next char.
Next i 'move to the next data field
Paul.
kiiid
Posted: 11:26am 05 Mar 2014
The clock is too high. Should be up to 4MHz
http://rittle.org
palcal
Posted: 02:26pm 06 Mar 2014
Still no go.
I connected to the Maximite just to confirm and all is OK.
So I reconnected to the Micromite using the 150 chip and checked all connections back to the actual chip. I changed the clock speed to 3Mz. and changed SPI(&H80) to SPI(&h3b) and used the code exactly as in the example on page 47, except I use Pin(7) instead of Pin(11). and all it returns is values of 255.
Paul.
kiiid
Posted: 02:44pm 06 Mar 2014
Are those pins supported by the SPI command? I have never tried the new micromite firmware neither have any details about its organisation so can't say anything about it from that point of view.
Edited by kiiid 2014-03-08
http://rittle.org
paceman
Posted: 03:47am 07 Mar 2014
Paul,
The MicroMite has fixed SPI pins whereas with the Maximite they could be assigned to any pins.
from MicroMite manual:
I/O Pins
For 28 pin chips pin 25 will become the clock output, pin 14 will be the data in (MISO) and pin 3 will become
the data out (MOSI). For 44 pin chips pin 14 is the clock, pin 41 the data in and pin 20 the data out.
When the SPI CLOSE command is used these pins will be returned to a “not configured” state. Then can then
be configured as per normal using SETPIN.
An SPI enable signal is often used to select a slave and “prime” it for data transfer. This signal is not generated
by this function and (if required) should be generated using the PIN function on another pin.
Greg
palcal
Posted: 04:14pm 07 Mar 2014
I am using all the correct pins, the GPS module tests OK, and the code is very simple.
But it just wont work.
Paul.
graynomad
Posted: 05:50pm 07 Mar 2014
Print lat,lon
Are variable names not case sensitive in MM BASIC?Edited by graynomad 2014-03-09
Rob Gray, AKA the Graynomad, www.robgray.com
Posted: 08:03pm 07 Mar 2014
Print lat,lon
"Naming Conventions
Command names, function names, labels, variable names, file names, etc are not case sensitive, so that "Run" and "RUN" are equivalent and "dOO" and "Doo" refer to the same variable."
graynomad
Posted: 02:45am 08 Mar 2014
OK, thanks.
