Local Time 18:48 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : cut the last digits from a number
plasma
Posted: 02:52pm 17 Feb 2014
hi ,
how to cut the last digits from a number ?
a= 1.550001
but i need a = 1.55
anyone ? thx
Posted: 03:08pm 17 Feb 2014
I would use:
A$=STR$(a) 'Convert numerical variable into a string
Number=VAL(MID$(A$,1,4)) 'Extract x.xx from the string and save it in 'Number'
Probably easier ways - others will chime in...
EDIT: This is not working, so I am thinking of something else. I expected it would - I will try this on MM - I am using the uM chip, just cos it is already hooked to the PC at the moment...
EDIT: I expect that FORMAT is the command you will need... (reading...)Edited by Grogster 2014-02-19
jman
Posted: 03:20pm 17 Feb 2014
a= 1.550001
but i need a = 1.55
a = Int(a * 100)
a = a/100
Jman
Posted: 03:23pm 17 Feb 2014
I get a result of 1.549998 from the uM chip using jman's code.
I will try this on the full size MM.
I am guessing that plasma wants only the first two significant figures, so wants 1.55, but not the rest of the number.
EDIT: OK, full-size MM gives interesting results too.
Using jman's code:
A=1.550001
Print A
A=INT(A*100)
A=A/100
Print A
Result is:
1.55
1.55
MM is automatically truncating 1.550001 right from the off.
If I use A=1.2345678, and run the same code, the result is:
1.2345678
1.23
EDIT: the above works on the uM chip too, so long as I use A=1.2345678
As soon as I use A=1.550001, I get odd results from the uM chip, and auto-trimming of A in the full size MM.
EDIT: A=1.55000678 is changed to 1.55 by the MM - any more then three zeros in the number, and everything to the right of that is ignored. A=1.23000456 results in A being equal to 1.23
...interesting...Edited by Grogster 2014-02-19
plasma
Posted: 03:50pm 17 Feb 2014
micromite source
where is no format function in micromite .
for r = 1 to 10
a= a+ 0.11
print a
next
shows the "same" for me , its floats inacuracy or ?
Edited by plasma 2014-02-19
Posted: 03:59pm 17 Feb 2014
All numbers are stored as floating point so very few will dicplay as expected.
What you need is a Format function for uMites's
Here is one I prepared earlier:
function uFormat$(x,p)
' given a number (x) and the required number of decimal places (p)
' returns formatted string. Negative and zero p is permitted
local x1, f$
f$=str$(cint(x*10^p))
if p>0 then
uFormat$=left$(f$,len(f$)-p)+"."+right$(f$,p)
elseif p = 0 then
uFormat$=f$
else
uFormat$=f$+string$(abs(p),"0")
endif
end function
This solves the display issue but you still might get caught out if you compare two numbers which appear to be equal.
JimEdited by TassyJim 2014-02-19
Posted: 04:21am 18 Feb 2014
We've covered the inherent behaviour of fp (floating point) numbers before. You can live with it in a variety of ways but it will always be there if you're outside what can be represented exactly. (It's the same on every computer using fp but often they use 64 or 80 bits rather than 32 so you tend to notice it less with those other computers.)
JohnEdited by JohnS 2014-02-19
psergiu
Posted: 09:39am 18 Feb 2014
  Grogster said   I get a result of 1.549998 from the uM chip using jman's code.
1.55
1.55
...interesting...
Fo the same code & same numbers, i don't think uM and MM should give different results - are you sure you put the same number of zeroes in both uM and MM ? If yes, we have a new uM bug for Geoff :)
Posted: 07:37pm 18 Feb 2014
uM chip with same code gave 1.549998, whereas CMM unit with same code gave me 1.55
Posted: 09:02pm 18 Feb 2014
Part of this discrepancy would because I used different code to turn a float number into a string in the Micromite,
In the Maximite I used the sprintf() routines provided by Microchip - but they took up 12K of flash!! So for the Micromite I built my own. The floating point routines are the same and the resultant number is the same, it is just that the conversion of the value to a string is a little different when we are at the extremeness of the 32 bit float range.
It is not that one is accurate and the other is not but more just different interpretations of the last few digits on an indistinct value.
jman
Posted: 09:16pm 18 Feb 2014
Rather odd
If we use 1.550001
> Print 1.550001 * 100
155.0001
> Print INT(155.0001)
155
> Print 155 / 100
1.5499998 !!!! What
> Print 155 / 10
15.5 !!! This one is correct
This would suggest a bug in the divide command :(
Jman
Edited by jman 2014-02-20
Posted: 09:34pm 18 Feb 2014
  jman said   Rather odd
Jman
Not a bug, just the way floating point numbers can behave.
You need to decide what resolution you want and use a function like the one I posted yesterday to display what you want to display.
OA47
Posted: 08:27pm 19 Feb 2014
  plasma said   hi ,
a= 1.550001
but i need a = 1.55
anyone ? thx
Plasma, had the same frustration when trying to display info on tera term with the micromite.
So I formatted them by multiplying by 100, taking the integer and rebuilding a string with the decimal point.
This is the result:
Posted: 08:30pm 19 Feb 2014
The image with the code is hard to read - probably not your fault - the forums automatically compresses photo data....
Can you please repost it in a code box?
Just makes it easier to read without straining my little eyeballs too much.
OA47
Posted: 09:04pm 19 Feb 2014
Sorry about that Grogster. Here's the code in a code box.
PrintToScreen:
PVVOLTS=Int(Pin(2)*1208.5)/100
APV$=Str$(Int(PVVOLTS*100))
PV$=Left$(APV$,2)+"."+Right$(APV$,2)
SLAVOLTS=Int(Pin(4)*1210)/100
ASV$=Str$(Int(SLAVOLTS*100))
SLA$=Left$(ASV$,2)+"."+Right$(ASV$,2)
TEMPC=Pin(3)*264-273
ATC$=Str$(Int(TEMPC*100))
TC$=Left$(ATC$,2)+"."+Right$(ATC$,2)
Print Date$;" ";Time$;" | PV ";PV$;" V | SLA ";SLA$;" V | TEMP ";TC$;
Print " DEG C | S1";SOL1;" | S2";SOL2
Return
Posted: 10:51am 20 Feb 2014
Ahhhhhhhh - that's better. My eyeballs thank you for the extra effort.
plasma
Posted: 01:52am 21 Feb 2014
thx a lot , sometimes i cant see a tree in the forest
