Local Time 18:48 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Brickwall for RTC on Micromite
OA47
Posted: 06:55pm 16 Feb 2014
Hope someone can see the error of my ways. I am trying to set and read the RTC on a I2C 1307 module with the Micromite.
The module and original code supplied by Jman in 2011 works perfectly on the CGMMSTICK1 and the Olimex Diunomite Mini both running MMBASIC version 4 but I cannot get the result from the Micromite running Version 4.5 beta.
Hope someone on the forum can shed some light on my problem.
(Sorry for the pun)
Graeme
MOBI
Posted: 07:42pm 16 Feb 2014
Hi Graeme,
My i2c functions seem to be doing "funny" things since I loaded up the latest beta. I have been using external i2c RTC, hex keypad and LCD. Everything appeared to be working ok on the previous beta version.
I am in Adelaide at the moment and won't be home till tomorrow evening where I can do a few reversion tests. Is it possible that the DS1307 and the "uM inbuilt" RTC command are in conflict - the addresses of both chips may be the same but the registers not? Just wondering as I don't have the data with me.
David M.
Posted: 08:03pm 16 Feb 2014
Graeme,
Can you post the code you are using.
I am using a PCF8563 and the inbuilt chock commands but I do have a DS1307 (somewhere) that I can test your code with.
I am not having any difficulties with other I2C devices on the MicroMite 4.5b6
OA47
Posted: 08:28pm 16 Feb 2014
  TassyJim said   Graeme,
Jim, I think this is the link:
2011-07-19_174444_RTC.zip
All the best
Graeme
Posted: 08:39pm 16 Feb 2014
Post the code in a CODE BOX:
Copy your code using either mouse(to left-click-hold and drag then right-click and COPY) or CTRL-A then CTRL-C with your code file open in something like Notepad.
Click the CODE button above the editing window
Place the cursor in-between the two CODE html tags(enclosed inside square brackets), and press CTRL-V to post your code.
Submit the new post - then your code should show up in a nice cute code box that everyone can read and examine.
This is an example of a code box.
Edited by Grogster 2014-02-18
OA47
Posted: 09:32pm 16 Feb 2014
The above link was the original article that Jman posted on TBS.
The code I am using is:
' Original Program for getting time and date from external RTC
' Presented by Jman 07/2011 on TBS altered for the Micromite V4.5beta3
600 ' Get time from time$ and date$
610 tempdec = Val(Left$(Time$, 2))
615 GoSub 1100
617 hours = hex
620 tempdec = Val(Mid$(Time$, 4, 2))
625 GoSub 1100
627 minutes = hex
630 tempdec = Val(Right$(Time$, 2))
635 GoSub 1100
637 seconds = hex
640 tempdec = Val(Left$(Date$, 2))
645 GoSub 1100
647 day = hex
650 tempdec = Val(Mid$(Date$, 4, 2))
655 GoSub 1100
657 month = hex
660 tempdec = (Val(Right$(Date$, 4)) - 2000)
665 GoSub 1100
667 year = hex
670 rtcctrl = &h10
680 rtcwday= &h1
690 ' Write Time to RTC
700 i2caddr = &h68 ' DS1307 I2C address
710 I2C open 100,100 ' Enable I2C
725 I2C write i2caddr, 0, 9, &h0, seconds, minutes, hours, rtcwday, day, month,
730 I2C close
770 Print "0=ok 1=nack 2=timeout"; MM.I2C
775 Print "RTC has been set to ";Time$;" ";Date$
780 End
1100 ' Convert to Hex
1110 hex = Fix(tempdec / 10) * 16
1120 hex = hex Or ((tempdec / 10) - (Fix(tempdec / 10))) * 10
1140 Return
Hope I got it all
I have tried pullup resistors from 4K7-20K with no change.
jman
Posted: 11:42pm 16 Feb 2014
Hi
Updated code for the MicroMite
Tested and working with a DS1307
ReadTime:
' I2C RTC based On DS1307 Secs,Mins,Hours,Day,Date,Month,Year,Control
Dim RTCbuff(8)
I2C write i2caddr, 0, 1, &h0
I2C Read i2caddr, 0, 8, RTCbuff(0)
I2C Close
sec$ = Str$(decimal)
BCDTEMP = RTCBuff(1)
BCDtoDec BCDTEMP
min$ = Str$(decimal)
BCDTEMP = RTCBuff(2)
BCDtoDec BCDTEMP
hours$ = Str$(decimal)
BCDTEMP = RTCBuff(4)
BCDtoDec BCDTEMP
day$ = Str$(decimal)
BCDTEMP = RTCBuff(5)
BCDtoDec BCDTEMP
month$ = Str$(decimal)
bcdtemp = rtcbuff(6)
BCDtoDec BCDTEMP
year$ = Str$(decimal + 2000 )
t$ = hours$+":"+min$+":"+sec$
D$ = day$+"/"+month$+"/"+year$
Time$ = T$
Date$ = D$
Return
'Convert to Decimal
Sub BCDtoDec (BCDTEMP)
Decimal = Fix(BCDTemp / 16) * 10
Decimal = Decimal + (BCDTEMP And &hF)
Jman
jman
Posted: 11:44pm 16 Feb 2014
And in case you want to set it
SetDS1307:
tempdec = val(left$(time$, 2))
DECtoBCD tempdec
hours = hex
tempdec = val(mid$(time$, 4, 2))
DECtoBCD tempdec
minutes = hex
tempdec = val(right$(time$, 2))
DECtoBCD tempdec
seconds = hex
tempdec = val(left$(date$, 2))
DECtoBCD tempdec
day = hex
tempdec = val(mid$(date$, 4, 2))
DECtoBCD tempdec
month = hex
tempdec = (val(right$(date$, 4)) - 2000)
DECtoBCD tempdec
year = hex
rtcctrl = &h10
rtcwday= &h1
' Write Time to RTC
i2c open 100,100 ' Enable I2C
i2c Write i2caddr, 0, 9, &h0, seconds, minutes, hours, rtcwday, day, month, year, rtcctrl
i2c Close
? "0=ok 1=nack 2=timeout"; mm.i2c
? "RTC has been set to ";time$;" ";date$
end
' Convert to Hex
Sub DECtoBCD (tempdec)
hex = fix(tempdec / 10) * 16
hex = hex OR ((tempdec / 10) - (fix(tempdec / 10))) * 10
And a little Picture of it going
JmanEdited by jman 2014-02-18
Ray B
Posted: 02:17am 17 Feb 2014
As an example of how a RTC can be set & read back to a serial port here is an example of how it is done in the basic form of "C" used in Arduino for those persons interested. Not really too difficult for persons familiar in programming in Basic.
C Programming does not get complicated until you delve into C++ & that's where I give up....
Example below is taken direct from examples that come with Arduino.
Note the neat structure of the code being:
*Declaration of libraries which you don't need to understand internally
* Loop of code used to setup program first time it is run - in this case enables serial port & sets time/date into RTC
* Program then runs in "loop"
#include <WProgram.h>
#include <Wire.h>
#include <DS1307.h>
void setup()
Serial.begin(9600);
RTC.stop();
RTC.set(DS1307_SEC,1); //set the seconds
RTC.set(DS1307_MIN,23); //set the minutes
RTC.set(DS1307_HR,12); //set the hours
RTC.set(DS1307_DOW,4); //set the day of the week
RTC.set(DS1307_DATE,5); //set the date
RTC.set(DS1307_MTH,3); //set the month
RTC.set(DS1307_YR,9); //set the year
RTC.start();
void loop()
Serial.print(RTC.get(DS1307_HR,true)); //read the hour and also update all the values by pushing in true
Serial.print(":");
Serial.print(RTC.get(DS1307_MIN,false));//read minutes without update (false)
Serial.print(":");
Serial.print(RTC.get(DS1307_SEC,false));//read seconds
Serial.print(" "); // some space for a more happy life
Serial.print(RTC.get(DS1307_DATE,false));//read date
Serial.print("/");
Serial.print(RTC.get(DS1307_MTH,false));//read month
Serial.print("/");
Serial.print(RTC.get(DS1307_YR,false)); //read year
Serial.println();
delay(1000);
RayB from Perth WA
Zonker
Posted: 02:19am 17 Feb 2014
hey Jman...
What kind of display are you using there..? Is it an IIC device also..? How do you talk to it..?
Thanks for any info..!
jman
Posted: 08:19am 17 Feb 2014
  Zonker said   hey Jman...
Hi
The display is a Nokia 5110 LCD. They are pretty cheap from Ebay
Nokia 5110
they display has an SPI interface so pretty easy to talk to
these display's are 84x84 pixels with NO built in fonts. The cool thing
is you can make custom graphics real easy (Like my degree symbol)
I can post my code if you are interested ?
Jman
BTW
Hope we are not hijacking this thread If so Glen please could you move it
atmega8
Posted: 09:38am 17 Feb 2014
Nokia Display from 2-4€ eBay...
https://www.sparkfun.com/products/10168
please show us your code, jman ;-)
atmega8
Posted: 09:43am 17 Feb 2014
Link to a bascom (Basic for atmega) code from a russian site,
Looks simple.
http://bascom.at.ua/publ/chasy_na_mege8_ds1307_i_displee_nok ia1100/1-1-0-71
OA47
Posted: 10:56am 17 Feb 2014
  jman said   Hi
ReadTime:
Dim RTCbuff(8)
I2C Close
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
BCDtoDec BCDTEMP
Time$ = T$
Date$ = D$
Return
'Convert to Decimal
Jman
Jman are you using beta 3?
This code still returns MM.I2C=1
jman
Posted: 11:09am 17 Feb 2014
Hi Graeme
I am using Beta 6
That error suggests a hardware error
Jman
jman
Posted: 11:12am 17 Feb 2014
  atmega8 said   Link to a bascom (Basic for atmega) code from a russian site,
Looks simple.
I will post my connections when I get home
It is real simple no pullup resistors 3.3V supply just 1 resistor
for the backlight
Posted: 11:47am 17 Feb 2014
What voltage are you running the DS1307 on?
It needs 5V.
OA47
Posted: 12:08pm 17 Feb 2014
It needs 5V.
Jim, you cracked it. The extra 1.7v made all the difference.
Thanks for your assistance and the other Shedders for their help.
Posted: 12:20pm 17 Feb 2014
Ahhhhh - 1307 running on 3v3 uM voltage then? Live and learn, and thanks for posting back that you found it.
Would anyone even need the internal uM RTC, if you are using an external one anyway?
My point being, that if you are going to use an external RTC with battery, why not just poll it whenever you need date and/or time, and not bother with the uM RTC at all?
I am a little at a loss to actually understand why the uM has a RTC in it, if it is not battery-backed up and in the native design for the uM by default. With the plethora of RTC modules available complete with on-board battery, you can drop pretty much all the code examples posted by members above, and just read/write the RTC module directly on the I2C, whenever you need that info.
Perhaps I am not thinking of something, but while we are on the RTC thread, I better ask that of the forums now...Edited by Grogster 2014-02-18
Posted: 12:38pm 17 Feb 2014
Graeme,
Glad that it's sorted and the exercise will help others.
The 8563 can run happily on 3V so it is good for battery operated systems.
The 8563 also has a timer/alarm function which can be used to wake the uMite up.
That's 2 good reasons for changing to the 8563 for the uMite.
Grogster,
Before I coupled the RTC to the uMite, I had my SETTICK interrupt tweaked to give timer drift as good as the typical RTC - a few seconds per day.
If you want minimum parts count, the internal clock is very useful.
