Local Time 18:49 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Micromite serial and power.
aargee
Posted: 10:40pm 14 Feb 2014
Finally getting all the bits together to experiment with the Micromite, I was looking for a USB to Serial board but couldn't wait for a Chinese one. I've just bought one of the Freetronics USB to Serial ones from Jaycar and it has the added bonus of an on board 3.3V regulator and a Vout pin on the serial connector.
You can have the serial port and power all in one!
Posted: 11:32pm 14 Feb 2014
Not sure of this particular device (link took me elsewhere) BUT do understand the power available as when it comes to driving outputs, too many devices (i.e. LEDs) and you could experience strange behaviour.
aargee
Posted: 12:59am 15 Feb 2014
True, but this is a minimum fuss, get you off the ground solution. The 1117 regulator should be able to drive a few LEDs for playing around, as well as the odd LCD, One wire device, etc. The MX32 only draws 25mA standalone at full speed, I doubt you will have current problems unless you require external transistors to drive your peripheral.
As far as strange behaviour, you haven't seen me in the workshop! ;-)
If you are using this set up, power up in this order: Connect Micromite to Serial/USB board, connect board to USB port, then run Teraterm. You won't see the Micromite boot message as it is booting at the same time as the serial device.Edited by aargee 2014-02-16
