Local Time 17:49 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Serial Port 7 bits - Teleinfo EDF
jpconil
Posted: 07:26am 27 Jan 2014
Hello,
Sorry, but the time I got registered on that forum, I fixed my problem.
A Duinomite is receiving the data send by my energy meter. The serial port configuration is 1200 bps, 7 bits, even, 1 stop bit and can't be changed...
It is not possible to declare something like :
OPEN "COM3:1200E7" AS #1
which is done straightforwardly by terminal programs.
The port is open as 1200, 8 bits, no parity and 1 stop bit.
The trick is to get a character at a time and to remove the parity bit.
OPEN "COM3:1200" AS #1
Rcd:
A$ = INPUT$(1, #1)
IF A$="" THEN GOTO Rdc
A = (ASC(A$) AND &h7F)
A$ = CHR$(A)
I hope it will help someone!
Frank N. Furter
Posted: 08:48pm 27 Jan 2014
Hello,
thanks a lot! I have often the same problem!
Frank
viscomjim
Posted: 04:06pm 28 Jan 2014
Hi Jpconil,
That is a fantastic piece of thinking! Thanks!
