Forum Index : Microcontroller and PC projects : Settick
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1056 |
I have an interupt set for every 10 minutes to check and analyse pins. SetTick 600000, CheckAnalogs,1 Is there a way of calling this interupt routine at program startup without having to duplicate the code as a subroutine? |
OK. Should have thought longer, I set a flag on startup and gave the routine a RETURN if the Startup flag was set, before the IRETURN. Startup=1: GOSUB CheckAnalogs / / CheckAnalogs: / / / / / If Startup=1 then Startup=0: RETURN IRETURN |
TassyJim![]() Guru Joined: 07/08/2011 Location: AustraliaPosts: 6629 |
firstrun = 1
settick 100, CheckAnalogs, 1 do loop end CheckAnalogs: if firstrun = 1 then settick 600000, CheckAnalogs, 1 firstrun = 0 endif print "Checking at "+time$ ireturn Jim VK7JH MMedit |
You might want to consider using defined Subroutines. It will also stop code going into a subroutine unwanted. You could then call that subroutine the first time and also use it for an interrupt routine. You do not need to use an IRETURN when using defined subroutines. It makes code easier to write and reuse. [code] CheckAnalogs settick 600000, CheckAnalogs, 1 do loop SUB CheckAnalogs print "Checking at "+time$ END SUB [/code] Microblocks. Build with logic. |
