Local Time 17:49 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : How to TX Raw Hex data in MM Basic?
JohnL
Posted: 07:26pm 23 Jan 2014
RE: MM Basic, Duinomite with 4 com ports including 2 hardware ports.
Need to output raw hex bytes on serial com port, no CR and no LF.
Advice would be appreciated.
ThanksEdited by JohnL 2014-01-25
Posted: 08:22pm 23 Jan 2014
To send the data
PRINT chr$(x);
where x is the value from 0-255 and the semicolon suppresses the CR/LF
if you need the data to appear as hex
PRINT HEX$( x );
JohnL
Posted: 08:35pm 23 Jan 2014
Perfect, works like a charm!
Thanks Jim
Posted: 01:17am 24 Jan 2014
Or
[code]
Print right$("0" + hex$(x),2);
[/code]
when you want to have a leading zero. The values will then always be 2 characters long.
You will probably need a separator otherwise when a character is missed the receiver will interpret the values wrong.
Easiest is to use a space.
[code]
Print " " right$("0" + hex$(x),2);
[/code]
JohnL
Posted: 02:23am 24 Jan 2014
Thanks TZ,
Will try that later.
At this stage I am using ASC(INPUT$(X, #Y) for receiving same single byte data by a MMbasic slave.
Any other suggestions?
