Local Time 17:50 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMEDIT2 - printing/display bug..
Posted: 12:29am 20 Jan 2014
If you have lines with multiple commands such as:
Print "Hello":Print "World"
First command is colour-syntaxed and printed, but commands after the first : are not capitalized and remain black and white. The printout reflects the display.
NOT a criticism, just a comment.
MMEdit2 version 0.9.1
Posted: 12:45pm 20 Jan 2014
If you have a space after the colon, all is well
I have made a change to the next beta which doesn't need the space but I am not sure if there are any unforeseen side-effects.
Please keep the comments coming, that is what beta releases are for.
I should have a uMite running soon and then I can do a few changes to MMedit to suit.
Posted: 02:03pm 20 Jan 2014
You are absolutely correct. If I put a space after the colon, the syntax changes to what it should be colour-wise and is auto-capatalized.
I have a lot of multi-command lines though, so I ain't adding all those spaces in.
The current stable version of MMedit I am using, which is 3.3.7(full editor, but no colour printing) does not care about no space after the colon - the example in my first post is correctly formatted and coloured.
Does not bother me - was just mentioning it.
MOBI
Posted: 02:35pm 20 Jan 2014
Just goes to show that all is not always "black and white"
David M.
