Forum Index : Microcontroller and PC projects : 86Duino
| Page 1 of 2 |
Dinosaur![]() Guru Joined: 12/08/2011 Location: AustraliaPosts: 360 |
Hi All Been searching for weeks to find a controller to suit my purpose. The wish list is: Programmable with FreeBasic. Run Dos or WinXPe. At least 4 A2D inputs.(Differential would be a bonus) At least 2 PWM outputs. At least 10 digital O/P At Least 4 digital I/P. Expansion Header for addon boards. Easy to connect to or Breadboard. Run unattended without display. LOW cost. Found this @ US$49: http://shop.dmp.com.tw/INT/products/24 Not in stock yet, but I am lining up for one at least. The only short coming on the site is that there is no detail, IE: How would you interface an lcd or monitor? What are the current limits of the I/O ? EDIT:16mA & 400mA on 3.3v Guess downloading the Vortex86 datasheets may give a clue. Interested in what others think of this device. Regards Hervey Bay Qld. |
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10074 |
I know you are looking at that unit(which looks interesting), but any reason you can't use the MM other then you seem to want MS-DOS or XPe? MM not fast enough? Smoke makes things work. When the smoke gets out, it stops! |
Hi All Some reasons: Grunt Memory to store collected data. Tools that I am used to (FreeBasic). No need to make an Interface board.(at least to test the prototype) The project I have in mind will expand to a GUI. Regards Regards Hervey Bay Qld. |
Okey dokey. Smoke makes things work. When the smoke gets out, it stops! |
elproducts![]() Senior Member Joined: 19/06/2011 Location: United StatesPosts: 282 |
That is very interesting. Though I don't see how you power it and the Arduino pins don't have the offset spacing that shields have so you can't plug shields directly in. I like the breadboard incorporated into the case. I'd be interested in the case alone. Their CNC computer looks like it might do the job but it's 4 times the price. Quite interesting though. Those are great designs. www.elproducts.com |
Why DOS or WinXPe rather than Linux? John |
Hi All There is a lot of information on how to use the whole thing still missing on the site. Even their eStore is still in trial phase, so very new. History, basically. DOS, because I am in complete control of the hardware. WinXPe , because I have lots of machines already running it. Using the combination of Assembly ,FreeBasic & CGUI I can compile for Dos, Win or Linux and the user couldn't tell the difference. Finally ,I AM a Dinosaur and have no desire to learn another system. Regards Regards Hervey Bay Qld. |
LOL!
Nice one. Smoke makes things work. When the smoke gets out, it stops! |
What will you do if the boards stop being available? (Such as the firm vanishing.) Are they multi-sourced? John |
Hi All The Vortex cpu has been around for a long time. One other advantage of being a "x86 compatible" is that the market is huge, but not at that price though. Had an email response from them. I have to admit though, IF there were an assortment of "Plugin" boards for the Maximite or the UBW32, then I would consider them. Particularly with the new more powerful PIC32 release. But it looks like all the work done in that area is aimed at the hobbyist with a soldering fetish. I have done that for more years then I want to admit to, so now I am a "Plug & Play" addict. Regards Regards Hervey Bay Qld. |
Thats where the arduino connectors come in. Lots of plug and play. www.elproducts.com |
There are a lot of boards that could be used except that you want DOS/WinXPe. You're seriously limiting your choice as you know. No problem if you're happy with that. John |
| 2001cpx Regular Member Joined: 03/10/2013 Location: CanadaPosts: 59 |
seem to be interessting, i've readed Doc about this product, and how you can connect an external video adapter and keyboard? on ISA 8 bit port? "Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2" |
mbramwel![]() Regular Member Joined: 10/07/2013 Location: CanadaPosts: 42 |
I think he should re-read the webpage closely. It is *supports* DOS, Linux, Windows. It does not say it *runs* DOS, Linux, Windows. To me it looks like an Intel micro controller, not a small PC. No video out, how would you see the output? I doubt if there is a BIOS. If it could boot DOS and run Basic programs, might be interesting to dig out the old DOS video games and play around. Anyone know for sure what is that unit? |
Nohrtec in Thailand makes a very similar product already for many years. They might even be the source. http://www.norhtec.com/products/index.html I have a few of those MicroClient JrSX and they work great. Main use is as a thin client using RDC to connect to windows servers. Microblocks. Build with logic. |
Very interesting products (JrSX). Yes, they clearly have Video out and keyboard/mouse ports. What I find difficult to decipher on some webpages is when they say "Dos, Linux, Windows" supported. Do they mean: (a) The unit can directly load & boot Dos, Linux, Windows (example: ARM boards can run Linux) or (b) Using a laptop running Dos, Linux, Windows, you can create software and download the compiled code onto the board. (example: arduino) A & B described above are very different scenarios. The unit mentioned by dinosaur might be A or B. I am not sure which one yet. |
I reckon it's (a). He wants to run FreeBasic and it makes EXEs so expects something like DOS/etc under that EXE. (Same concepts with other names if Linux.) For the other scenario I think it would have to be phrased quite differently. (Or they deliberately mislead, but I hope not.) John |
if we need to pay more than 100$,better to buy microAtx like Kino,which i have. this board have 2 ethernet,4 or 6 USB port,lcd port,Vga out,Hdmi,4 serial,1 485,sound in out,20 or more i/o,keyb,ps2,sata,ide,pci ETC. and very smaller 6 inch by 6 DosDuino if Exist like think,can be a new player. i have sold a lot's of KINO in my industrial project,now i use Maximite,i know, it's not the same thing,but , for industrial automation,no need to have a lot's of graphics, and do the job,and more. all electro mecaniks,here,in the very big plant(over 1200 worker) like a basic language and can be modified on the fly,and no need to be an engineer to only change a parameter. "Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2" |
Hi All The processor definitely supports Dos,FreeDos,Win & Linux. I have used this processor before on other boards. After reading the cpu manual, it appears that the vga is supported through a PCI bus. But I cant see any connectors for it, on the circuit diagrams that they provide. So, when all else fails , ASK. And I did. I got an answer to a previous email, so let's see. Regards Hervey Bay Qld. |
Thanks for the update. That system and the MM based systems are great for logging output from devices. I agree on the 'no graphics' comment for industrial installations. The part I thought was interesting is the case with the embedded breadboard. keep us updated on what you find out. |
| Page 1 of 2 |
