Local Time 16:02 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can’t Connect with MMEDIT
2001cpx
Posted: 10:45am 27 Dec 2013
MMedit v 3.4.0
Very Strange,Worked With MMedit last times with no problem.
now each time i do Chat to Maximite An Error 0 Messagenotunderstood
and Error 0 Bad file handle ;#recRaw
Can Connect to explore SDcard ok
tried to re install,changed USB Outlet,checked under files COMPORT ok
any help appreciated
thanks in advance
"Color Maximite,(Duinomite-Mega,Mini),CGmmStick,GCmicroboard2b,Micromite + explore 64,100,LCD backpack,Lcd Backpack V2,TFT Backpack,Micromite Extreme,Armmite L,F,H,CMM2"
2001cpx
Posted: 02:43pm 27 Dec 2013
Tryed on Another computer and everything work fine
- removed all Maximite related usb driver (With USBDVIEW)
- re-installed new driver(found on Geoff Project pages)
- re-installed MMedit
Work With MM Master File,but not With MMchat
very strange,surely i have installed one software and modified some important files
- tried Cleanup Program CCleaner,Tuneup
-Scanned With Malwarebyte PRO
-Scanned with Zonealarm
i will continue to found the problem,any help will be greatly appreciated
Posted: 11:11pm 27 Dec 2013
Strange,
#recRaw refers to a debug file that only comes into play while doing XMODEM file transfers.
I should have disabled it fully on the release code.
I expect that there is something in your configuration files that MMEdit is not happy about.
You could try uninstalling MMEdit and then deleting the data folder.
It's location can be found from Help/About.
This will then allow a clean installation of MMEdit.
Before that, you could try replacing the file MMEdit.tkn in the program folder with the one in the attached ZIP file.
I have (hopefully) disabled the culprit fully.
2013-12-28_091048_MMedit.zip
I have been working on the all new version of MMedit and I am happy with the progress.
There are plenty of differences between the Windows and Linux versions for me to discover.
The one big section of code left to tackle is the VT terminal.
Posted: 01:49pm 28 Dec 2013
I have been happily using MMEdit2 version 0.9(pre-release alpha) that you put up here a while ago, just for the colour printing and it is fantastic. I still use the stable v3 for editing etc, though.
...but I digress from the topic of this thread...
2001cpx
Posted: 03:49am 29 Dec 2013
RESOLVED!!!!
  Quote  You could try uninstalling MMEdit and then deleting the data folder.
Thank you Very Much!!
Yes that's resolved my problem,only add/delete program will not suffice,
i need to remove Manually in Documents and Setting and etc...
I think if you never replyed, I would never find!
thanks Again.and i Like MMedit!!!!
Posted: 12:34pm 29 Dec 2013
A happy ending - I like those.
