Local Time 16:03 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Passing Reference to Subroutine
Zonker
Posted: 04:25am 30 Nov 2013
Happy Thanksgiving to all at the Shed..!!
Just a quick question... I have several dimensioned arrays that contain settings data.. I want to create a common subroutine that would use the data from the different arrays.. When called, I need to pass a reference to the wanted array into the subroutine.. I am sure there is a way to do this..! (it's my noobie calling)
dim RPM(12) ' create storage for "RPM" gauge
RPM(0)=0 ' gauge input value
RPM(1)=100 ' gauge MAX scale
RPM(2)=50 ' X-pos of gauge drawing
RPM(3)=50 ' Y-pos of gauge drawing
RPM(4)=yellow ' gauge frame color
RPM(5)=black ' gauge background color
RPM(6)=green ' gauge scale color
RPM(7)=yellow ' gauge numbers color
RPM(8)=red ' gauge needle color
' the last 4 bytes store object state change data
' the sub call
plot_scale (RPM)
' more code...
SUB plot_scale(g_info)
local center_x, center_y
center_x = g_info(2) + 84 ' get passed X-pos
center_y = g_info(3) + 120 ' Y-pos
' more code...
END SUB
I am playing around with the code that Bovist created that draws meter objects and wanted to make it into a common set of routines stored in a LIB file...
Thanks for any help, and Happy Holidays everyone..!!
Posted: 08:39am 30 Nov 2013
You can not use arrays as an argument for a sub or function.
from the MMBasic manual , page 14
[quote]
Additional Notes
There can be only one END SUB or END FUNCTION for each definition of a subroutine or function. To exit
early from a subroutine (ie, before the END SUB command has been reached) you can use the EXIT SUB
command. This has the same effect as if the program reached the END SUB statement. Similarly you can use
EXIT FUNCTION to exit early from a function.
You cannot use arrays in a subroutine or function's argument list however the caller can use them. For
example, this is a valid way of calling the Swap subroutine (discussed above):
Swap dat(i), dat(i + 1)
This type of construct is often used in sorting arrays.
[/quote]
All is not lost, because what you could do is pass a string.
A string is kind of an array, existing of byte values.
Larger numbers can be a set of bytes, depending how large the values can be.
Edited by TZAdvantage 2013-12-01
James_From_Canb
Posted: 08:57am 30 Nov 2013
We had the same problem with an old system at work. We resolved it by putting all the values into a single array and added another field for, in your case, the gauge type. Pass the gauge type as a string parameter to your routine.
James
Zonker
Posted: 09:15am 30 Nov 2013
Thanks Gent's..!!
I am sure I can get around this somehow... just more code...
paceman
Posted: 05:25pm 30 Nov 2013
James
Hi james - good to see you back on deck again.
Greg
