Local Time 14:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CMM v4.4(a) bug
Juri74
Posted: 08:13am 23 Oct 2013
hello i think i've just found a bug. it's in v4.4 but because v4.4a only fix a PIN 7 bug probably this bug is in 4.4a too
try this little program:
Hello()
Print "Where is the bug?"
End
Sub Hello()
Print "Hello there!"
Return
could someone confirm this please? :)Edited by Juri74 2013-10-24
CircuitGizmos
Posted: 10:42am 23 Oct 2013
So what happens? Are you saying it is OK that return works?
Hello()
End
Sub Hello()
END SUB
Posted: 03:56pm 23 Oct 2013
It does work but only because Return does the same thing as End Sub - however this may change in the future.
The correct syntax is:
Hello
End
Sub Hello
Juri74
Posted: 10:18am 30 Oct 2013
ok, thank you Geoff
