Forum Index : Microcontroller and PC projects : Flexible PCBs?
Grogster![]() Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10074 |
Does anyone know of any PCB houses that can make flexible PCB's? You know - like the plastic films used inside keyboards to form the matrix etc. I have a need to make a flexible PCB, but am having a bit of trouble deciding on which PCB houses offer this service. Has anyone here had flexible PCB's made, and if so, where did you go to get them made? Smoke makes things work. When the smoke gets out, it stops! |
| kiiid Guru Joined: 11/05/2013 Location: United KingdomPosts: 671 |
I have made flexible PCBs before (0.15mm thickness) with PCBcart in China. The quality was great. You need to contact them by email though as I think there wasn't such option in the online ordering. http://rittle.org -------------- |
itead studio does flexible boards. I have not used this service but they make great standard PCBs (which I and TZAdvantage recommend). Geoff Geoff Graham - http://geoffg.net |
darthmite![]() Senior Member Joined: 20/11/2011 Location: FrancePosts: 240 |
I get my PCB from itead studio too , great service , but i never try the flexible PCB services. Darth. Theory is when we know everything but nothing work ... Practice is when everything work but no one know why ;) |
Excellent - thanks very much for the replies, guys. I will check out all these places and examine my options. Smoke makes things work. When the smoke gets out, it stops! |
