Local Time 14:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMchess?
kiiid
Posted: 12:14am 10 Oct 2013
Just out of curiosity, has anyone ever attempted to make or port some chess on the 'mite? The real one I mean, not the colour...
http://rittle.org
Frank N. Furter
Posted: 08:40am 10 Oct 2013
Hi Kon,
I tried a little bit an old BASIC chess code and it seems to work...
The code has a graphic output that not work properly but the moves seems to be ok.
My aim is to create a little servo robot arm (controlled by a Maximite) to do the moves!
Frank
kiiid
Posted: 12:16pm 10 Oct 2013
Was it the GWChess? I played a bit with its code these days. It contains quite a few LOCATE commands which initially I thought will be fine. But then in fact I had to convert them all because the Microsoft's format is <line,column> while MMBasic interprets as <column,line>. LOCATE also has a third parameter in the original code, which causes MMBasic to exit with an error. Yet, after converting the whole output, the code failed with too many nested GOSUBs and I got tired from it :)
What you are trying to do sounds interesting. Maybe when you build it you will share some photo/video showing your robotic player?Edited by kiiid 2013-10-11
http://rittle.org
Frank N. Furter
Posted: 07:51pm 10 Oct 2013
I have annoyingly too little time for those projects... But when I have something working I will it exhibit here...
Frank
