Local Time 14:34 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Decoding DTMF
OA47
Posted: 12:34pm 05 Oct 2013
I thought I might throw this one onto the think tank. Has anyone any ideas on how to decode DTMF in basic with a 'mite?
kiiid
Posted: 12:59pm 05 Oct 2013
I don't think it is going to be an easy job using the 'mite only...
Try by connecting MT8870D to it.Edited by kiiid 2013-10-06
http://rittle.org
Gordz
Posted: 06:23pm 05 Oct 2013
Its pretty tricky because is is two frequencies at once. MT8870 is the way to go for sure
phiber
Posted: 01:01pm 12 Oct 2013
This is not as hard as it first seems in software. While it's obviously really easy to add an MT8870 to your circuit, if you'd rather do without an extra chip, the PIC32 has more than enough processing power to do DTMF detection in software.
The textbook algorithm most commonly used in telephony for DTMF and MF detection is the Goertzel algorithm, which is a type of digital filter. You can read about the math behind it in wikipedia.
There is a REALLY good example of Goertzel purely in software, used in the Asterisk software PBX. You can peruse the DSP code here. I chose the older Asterisk 1.0 since the codebase was simpler back then.
Mark
  Gordz said   Its pretty tricky because is is two frequencies at once. MT8870 is the way to go for sure
Posted: 03:15am 13 Oct 2013
Some explanation etc hereDTMF
Posted: 10:21am 13 Oct 2013
  JohnS said   Some explanation etc hereDTMF
That is a very good explanation and worth some experimenting.
