Local Time 15:13 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic CAN-BUS connected Carputer
psergiu
Posted: 05:35pm 26 Sep 2013
Hello,
I want to use a Maximite/Duinomite connected to the CAN interface of my car and showing various info on a small composite LCD.
As far as i know, there's a special version of MMBasic with CAN support. But there my knowledge stops. Now the questions:
1) What kind of board is compatible with that MMBasic+CAN version ? Only Duinomite Mega or can i use a Color Maximite + some extra CAN hardware instead ?
2) I saw that the Duinomite Mega has a 3-Wire CAN interface connector - how do i connect that to the car's OBDII port ? Directly or do i need extra hardware ?
Thanks.
BobD
Posted: 08:11pm 26 Sep 2013
Unless you have some special things in mind you may want to look at what is available off the shelf. There is a small device that can be bought for less than AU$10 delivered from eBay that will allow a Bluetooth connected device access to many of the monitoring functions via OBDII. I have one of these gadgets and it sticks out of the OBDII socket by 20mm. Other dimensions are 24mm and 46mm. Search on Google or eBay for ELM327. It is also in Wikipedia. I only received this a couple of days back and have not had a chance to try it out. I believe you can get software (free and paid) for PCs and tablets including Android and Apple devices. Mine came with PC software on a small CD.
Posted: 08:47pm 26 Sep 2013
For CAN you'd connect to the CAN pins and ground. Which ground? Well, it SHOULD be the signal ground but beware that car makers can be a bit clueless so you may need to use the other ground. D'oh.
Look up OBD DLC to see the pins.
ELM327 comes in 2 main types, BT (hard to use from a 'mite) and USB (er, also hard - probably harder than BT).
Kinda boring to use an elm327, though. (None of the existing programs will work on a 'mite but then most aren't available as source either.)
I do recommend reading the elm327 data sheet at elmelectronics.com/DSheets/ELM327DS.pdf‎
JohnEdited by JohnS 2013-09-28
CircuitGizmos
Posted: 04:18am 27 Sep 2013
CGCOLORMAX2 plus a CAN chip. The CAN circuit is on the board just waiting for a chip and connections to a bus.
http://www.circuitgizmos.com/products/cgcolormax2/cgcolormax 2.shtml
psergiu
Posted: 06:05am 27 Sep 2013
BobD - Thanks, but i want to use a MMBasic device. Much easier (for me) to program for, cheaper, faster boot time and i am not restricted by the form factor.
JohnS - what happens if i connect the wrong ground ?
CircuitGizmos - cool ! What chip is that ? I supposed the CGCOLORMAX2+CAN chip is supported by the MMBASIC 4.x CAN firmware out of the box - right ?
Thanks.
Posted: 06:19am 27 Sep 2013
If the car maker's goofed you'll have no ground.
Check with DVOM.
CircuitGizmos
Posted: 02:30am 28 Sep 2013
  psergiu said   BobD - Thanks, but i want to use a MMBasic device. Much easier (for me) to program for, cheaper, faster boot time and i am not restricted by the form factor.
Thanks.
Specific chips are mentioned in the FAQ section of the Beginning Maximite doc. You need to flash the CAN version of the firmware onto the Colormax2.
Lopezjm2001
Posted: 04:29am 08 Oct 2013
Thanks.
Hi Psergiu,
I have written a MMbasic program to use with a CGcolormax2 with a CANbus port. You can see it at
http://priuschat.com/threads/my-duinomite-mega-canview-v4-eq uivalent-project.112429/
It was written for a Toyota Prius 2004-2009. You may find some of my MMbasic code helpfull.
Edited by Lopezjm2001 2013-10-09
Lopez
jman
Posted: 08:37am 08 Oct 2013
Hi Lopezjm
The link you provided does not work
Jman
Posted: 10:30am 08 Oct 2013
Try this link:
JimEdited by TassyJim 2013-10-09
Posted: 08:46pm 08 Oct 2013
Trying to download the code (step 11) doesn't work - just get
PriusChat - Error
The requested attachment could not be found
psergiu
Posted: 06:38am 09 Oct 2013
Thanks Lopez !
I downloaded the file - as soon as i have all the hardware in place, i'll try to adapt your software for Camry/Solara and i'll provide the updates here.
JohnS - See the attached file at the bottom of the post - clock on "MMBASIC 4.4 CANVIEW PROGRAM 09102013.zip"
Posted: 07:13am 09 Oct 2013
Oh - OK, thanks, how odd.
Step 11 doesn't work as posted, though.
JohnEdited by JohnS 2013-10-10
paceman
Posted: 04:46pm 09 Oct 2013
  TassyJim said   Try this link:
Err... Jim, apart from the slightly different purple colour, what was different about your link that made it work?
Greg
Posted: 08:14pm 09 Oct 2013
The characters in both links are the same (by eyeball) but the actual URLs are not.
(Look at HTML to see.)
Lopezjm2001
Posted: 11:27pm 09 Oct 2013
  psergiu said   Thanks Lopez !
No worries. Is the Camry Solara a Hybrid?
JohnEdited by Lopezjm2001 2013-10-11
Lopez
