Local Time 13:53 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MM WinCE
Juri74
Posted: 04:17am 23 Aug 2013
Hello people,
does anyone know if it's possible to connect a Maximite (DM,CMM,UBW32 etc) to a WinCE 6.0 system?
thank you!
Juri
Posted: 11:19am 23 Aug 2013
If the WinCE system has serial,IR or bluetooth it should be possible.
You will need ir or bluetooth to serial on the maximite.
If not, you could use a serial to ethernet or WIFI adapter on the maximite.
There are plenty of telnet terminals for WinCE.
Juri74
Posted: 01:50am 25 Aug 2013
can i direct use the serial on usb to direct connect the maximite to wince device using the usb cable?
