Local Time 12:15 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : SAVE from the full screen editor
hitsware
Posted: 01:09pm 19 Jul 2013
DuinoMite MMBasic 4.4
No PC ....
I can save routines with SAVE
from the first screen but F1 on
the 'editor' page doesn't work.
Am I missing something ?
Blackened
Posted: 02:40pm 19 Jul 2013
If you load a file into memory, then edit, then F1 save, you are only saving your changes to the copy in RAM. EG:
LOAD EXAMPLE.BAS
EDIT
'file editing in full screen editor
'F1 key press
However editing a file stored on a: or b: should cause the F1 key to save back to the original file.
NEW
EDIT EXAMPLE.BAS
'More file editing
'F1 key press
Of course, I could be wrong LOL.
Check out the MMBasic manual for a better description of how the full screen editor handles saves.
hitsware
Posted: 04:42pm 19 Jul 2013
  Blackened said   If you load a file into memory, then edit, then F1 save, you are only saving your changes to the copy in RAM. EG:
LOAD EXAMPLE.BAS
EDIT
'F1 key press
NEW
EDIT EXAMPLE.BAS
'More file editing
'F1 key press
Maybe I'll just use F1 as a prompt to SAVE ........
