Local Time 13:04 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Sequencing Code
marcwolf
Posted: 04:02pm 18 Jul 2013
Hi folks. I'd thought I's paste some code I am working on.
Basically the concept is to read through set's of servo sequences in different files with each file containing multiple sets, different record length, an a primitive command looping and jump system.
Please feel free to use it.
Also many thanks Geoff for the Random File Access for without that this sould not have been possible at all.
Dave
' Sequence Processing System
option base 1 ' sets arrays to start at 1
dim RecElem(5,7)
Dim FileElem(5,2)
' File Structure
' First 40 bytes contain Rec Len, Num Seq, and Comment
' Then 100,200,300 bytes are for first seq header.. seq num, start rec, num rec in sequence
' Byte 2000 is start of first sequence
'File Example
FileElem(1,1) = 64 ' Record Length
FileElem(1,2) = 6 ' Num of Sequences
' Record Example
RecElem(1,1) = 0 ' Seq Num
RecElem(1,2) = 0 ' Curr Rec
RecElem(1,3) = 0 ' Delay Count
RecElem(1,4) = 0 ' Byte Offset to first seq position
RecElem(1,5) = 0 ' Recs in current sequence
RecElem(1,6) = 0 ' Last Branch
RecElem(1,7) = 0 ' Last Pos before Branch
' Globals
DefFldLen = 10 ' default numberic field len
DefCmdOff = 21 ' Skip to Command
Function NumPad$(iNum, FldLen) ' Pad Numbers with specified Len
LOCAL a$
a$ = string$(FldLen,32)
NumPad$ = right$(a$ + str$(iNum),FldLen)
End Function
Function Pad$(iNum) ' Pad Numbers for Saving
LOCAL a$
a$ = string$( DefFldLen,32)
Pad$ = right$(a$ + str$(iNum), DefFldLen)
End Function
function Get$(FileNum, Recnum)
' Get offset record pos using Seq Details
LOCAL t
LOCAL q$
t = (FileElem(FileNum,1) * (RecNum-1)) + 1 ' Rec Number
t = t + RecElem(FileNum,4) ' Add Start Offset
If t < LOF(#FileNum) then
seek #FileNum, t
q$ = input$(FileElem(FileNum,1),#FileNum)
else
q$ = "EOF"
endif
Get$ = q$
End Function
function GetRec$(FileNum, RecLen, Recnum, OffSet)
' Get absolute record position
LOCAL t
LOCAL q$
t = (RecLen * (RecNum-1)) + 1 ' Rec Number
t = t + Offset
seek #FileNum, t
q$ = input$(RecLen,#FileNum)
else
q$ = "EOF"
endif
GetRec$ = q$
End Function
SUB PutRec(FileNum, RecLen, Recnum, OffSet, Rec$)
local t
t = t + Offset ' Add Offset
seek #FileNum, t
Print #FileNum, Rec$;
End SUB
Sub LoadSeq(FileNum, SeqNum)
' Load the SEQ Header into the Array
SeqNum = 100 + ((SeqNum-1) * 100)
Seek #FileNum, SeqNum : RecElem(FileNum,1) = VAL(INPUT$(DefFldLen,FileNum)) ' Seq Num
Seek #FileNum, SeqNum + 11 : RecElem(FileNum,4) = VAL(INPUT$(DefFldLen,FileNum)) ' Byte Offset
Seek #FileNum, SeqNum + 22 : RecElem(FileNum,5) = VAL(INPUT$(DefFldLen,FileNum)) ' Recs in Sequence
RecElem(FileNum,2) =0: RecElem(FileNum,3) =0
Sub LoadFile(FileNum, FileName$ )
' Load the File Header
open FileName$ for RANDOM as #Filenum
SEEK #FileNum, 1
FileElem(FileNum,1) = VAL(INPUT$(DefFldLen,#FileNum))
SEEK #FileNum, 12
FileElem(FileNum,2) = VAL(INPUT$(DefFldLen,#FileNum))
Function ProcessRec$(FileNum)
Local Rec$, Cmd$, Q
' Are we doing a Delay Looping ?
If RecElem(FileNum,3) > 0 then
RecElem(FileNum,3) = RecElem(FileNum,3) -1
ProcessRec$ = ""
Exit Function
' Are we at STOP ?
If RecElem(FileNum,2) = -99 then
' No Op
ProcessRec$ = ""
Exit Function
ReEntryIncr:
' Incr Pointers
RecElem(FileNum,2) = RecElem(FileNum,2) + 1
ReEntry:
' Are we at End of Seq? Then Loop to Beginning
If (RecElem(FileNum,2) ) > RecElem(FileNum,5) then
RecElem(FileNum,2) = 1
ENDIF
' Get the Actual Record
Rec$ = get$(FileNum,RecElem(FileNum,2)) ' Get REAL Record
' If "EOF then treat as NOP
If Rec$ = "EOF" Then
ProcessRec$ = ""
EXIT FUNCTION
Rec$ = MID$(Rec$,DefCmdOff) ' Remove Recs Seq Nums
Cmd$ = LEFT$(Rec$,2) ' Get the first 2 chars for command
'XX - Stop. Don't progess any more
'XJxxxx - Jump to Record xxxx back from Current
'XSxxxx - Jump to Sequence #xxxx
'XDxxxx - Delay for x number of interactions and then to next
If Left$(Cmd$,1) = "X" Then
If Left$(Cmd$,2) = "XX" then ' STOP
ProcessRec$=""
Exit Function
If Left$(Cmd$,2) = "XJ" then ' JUMP To Record
Q = val(mid$(Rec$,3,10))
RecElem(FileNum,2) = Q
Goto ReEntry
If Left$(Cmd$,2) = "XD" then ' Delay for X Reads
Q=val(mid$(Rec$,3,10))
RecElem(FileNum,3) = Q
ProcessRec$ = ""
EXIT FUNCTION
If Left$(Cmd$,2) = "XS" then ' Sequence Change
loadseq(FileNum, Q)
RecElem(FileNum,2) =1:RecElem(FileNum,6) =0: RecElem(FileNum,7) =0
Goto ReEntry
' Return Back Servo Command
ProcessRec$ = Rec$
End Function
Sub CreateTempFile(FileNum, FileName$, RecLen, Title$, NumSeq)
' Creates a Test File
LOCAL RecCont$, X,Q,T, StartPos
X=0:Q=0:T=0:StartPos =0
RecCont$ = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456 789"
SEEK #Filenum,1
print #Filenum, pad$(RecLen), pad$(NumSeq), Title$ ' Reclen, num seq, file comment''
StartPos = 2000
For x = 1 to NumSeq
seek #Filenum,(x * 100)
Q = (INT(RND() * 20) +1)
print #Filenum, pad$(X),pad$(StartPos),pad$(Q) ' Seq Num, Start Rec,
print Filenum, pad$(X),pad$(StartPos),pad$(Q) ' Seq Num, Start Rec,
For t = 1 to Q
recInfo$ = left$(pad$(NumSeq) + pad$(t) + RecCont$,RecLen)
PutRec Filenum,RecLen,t,StartPos, recInfo$
next
StartPos = StartPos + (RecLen * q) + 100
Next
Close #FileNum
main:
' Create Test Files
CreateTempFile 1, "Ears.dat", 64, "Ears", 4
Print
CreateTempFile 2, "Muzzle.dat", 76, "Muzzle", 6
'END
loadfile(1,"Ears.dat") ' Load File 1 Header
loadfile(2,"Muzzle.dat") ' Load File 2 Header
print FileElem(1,1),FileElem(1,2) ' Display File 1 Header
print FileElem(2,1),FileElem(2,2) ' Display File 2 Header
loadseq(1,1) ' load Seq 1 from File 1
loadseq(2,2) ' Load Seq 2 from File 2
print RecElem(1,1),RecElem(1,4),RecElem(1,5) ' Show Seq 1 Header
print RecElem(2,1),RecElem(2,4),RecElem(2,5) ' Show Seq 2 Header
' RecElem(2,2) = 10 ' Seed to start at Record 10 For Testing
For x = 1 to 10 ' Get 10 Records
' Print 1, RecElem(1,2), ProcessRec$(1)
Print RecElem(1,1), RecElem(1,2), ProcessRec$(1)
next
print RecElem(1,2), RecElem(2,2) ' Show Record Pointers
' Wait
input a$
Coding Coding Coding..
Keep those keyboards coding..
RAW CODE!!!!!
