Local Time 12:16 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Duinomite (or ColorMaximite) & Midi
hitsware
Posted: 02:10am 16 Jul 2013
I just got 1 of these:
http://shop.moderndevice.com/products/fluxamasynth
The midi com standard says:
32.25 kbps
1 start bit
1 stop bit
I can't figure how to get the start and stop bits ?
The Duinomite will do the 32.25K but the manual
(OPEN COM) doesn't mention # of bits or start or stop
The ColorMaximite manual says the com is 8 data bits,
no parity, 1 stop bit (only speed adjustable)
Thanks for any insight ....
Posted: 08:33am 16 Jul 2013
Chances are it's always 1 start bit and will actually be 1 stop bit.
Try it :)
I suppose you could look at the C code to see what it does...
hitsware
Posted: 11:18am 16 Jul 2013
Thanks .... Yea, looks like maybe the default settings are right.
(though I'm not positive)
Can't get a squeek though :(
" For 8-N-1 encoding, only 80% of the bits are available for data
(for every eight bits of data, ten bits are sent over the serial
link — one start bit, the eight data bits, and the one stop bit)."
Posted: 11:21am 16 Jul 2013
You might need to invert the signal.
JTR0701
Posted: 12:15pm 16 Jul 2013
I think you will find that MIDI is 31.25kb/S and not 32.25kb/S. The start and stop bit are added by the PIC32 hardware UART and unless MMBasic provides an option for TWO stop bits then all the defaults are OK.
As TZ points out you do need to be more concerned about compatible physical interfacing with your module, particularly with the polarity and voltage levels of the MIDI signal. The data sheet for the module should have this information.
hitsware
Posted: 01:30pm 16 Jul 2013
Right. Senior moments.
I hope so.
I'm pretty sure I'm good there. The synth normally goes on an Arduino
board and snaps right on to the DuinoMite. Feeding it random numbers
should get some noise if even the data was inverted but doesn't ... Edited by hitsware 2013-07-17
JTR0701
Posted: 01:35pm 16 Jul 2013
  hitsware said   Feeding it random numbers
No! The start and stop bits would also be inverted. What you will get is framing errors on the MIDI module, not random sounds.
hitsware
Posted: 04:26pm 16 Jul 2013
I thought the 'start and stop bits' were automatic from the urt
(independent of the data) ????
Posted: 08:01pm 16 Jul 2013
Yes, automatic but if they're inverted then you'll need to correct (reinvert) them.
Do check the volts, too, as the PIC32 is a 3.3V device and maybe your Arduino is 5V?
JohnEdited by JohnS 2013-07-18
hitsware
Posted: 05:36am 17 Jul 2013
Volts are OK
12V up from to Fluxamasynth 'shield' from DuinoMite
Onboard 3.3V regulator, so synthchip is 3.3V
Data coming up is 3.3V pulsetrain
I need to look close at the chips data sheet.
Maybe there is an initialization code or ????
hitsware
Posted: 10:20am 18 Jul 2013
Problem Solved !
http://www.thebackshed.com/forum/forum_posts.asp?TID=5938&PN =1&TPN=1
Posted: 10:59am 18 Jul 2013
Excellent!
